Rear Window Surround
Posted: Wed Jun 29, 2011 10:24 pm
by Mai Ki-Ki
I have a standard EK (61) with just the rubber trim and no steel / stainless trim. Front screen has steel (painted) surround that is body colour.
As I don't want to replace the rear screen just yet (or pull it out) has anyone fitted a rear surround by cutting off the section that usually goes into the rubbers... and then just glue / screw fix in place...?
Cheers Maiki
Re: Rear Window Surround
Posted: Fri Jul 01, 2011 8:48 pm
by Trev
I just got it after reading it for the 3rd time
Pretty sure you mean cutting the part of the stainless trim, that usually goes inside the rubber and holds it in place, off?
If so I have never heard of it being done before.
Might be easier to put the special rubber in with the stainless fitted the rite way.
Posted: Sat Jul 02, 2011 6:09 pm
by Sputzwagon
Posted: Thu Jul 07, 2011 3:48 pm
by Mai Ki-Ki
Yeah, that was the idea.....Might have to get a price on redo-ing the rear screen (new rubber + stainless).
Cheers M
Posted: Thu Jul 07, 2011 5:45 pm
by Trev
M, pm sent.
Posted: Thu Jul 07, 2011 7:37 pm
by Mick
Mai Ki-Ki wrote:I have a standard EK (61) with just the rubber trim and no steel / stainless trim. Front screen has steel (painted) surround that is body colour.
Cheers Maiki
pretty sure i know what yor talking about, removing from the stainless the part that inserts into the rubber if so yes i've done it, used srews where they normally would go and a small amount of sikflex to hold it on
Posted: Sun Jul 10, 2011 11:18 pm
by Mai Ki-Ki
harry186 wrote:Mai Ki-Ki wrote:I have a standard EK (61) with just the rubber trim and no steel / stainless trim. Front screen has steel (painted) surround that is body colour.
Cheers Maiki
AH!
strong metal cutters or grinder/cut-off wheel to remove the stainless part...?
Thanks. M
Posted: Mon Jul 11, 2011 11:54 am
by Mick
i used angle grinder useing cut off wheels and grinding make sure you get discs for stainless steel cause you'll chew through them
Posted: Fri Jul 15, 2011 10:03 pm
by Sputzwagon
