Torana brakes on to HR cross member
cramfest
Post by cramfest »
Hi all. I'm just after some advise. I have heard that you can fit complete torana stub, disc and caliper set to HR cross member. If anyone can help will be much appreciated.
Want to know:
- What model Torana to use
- Which steering arms to use (Torana/HR)
stinky
Re: Torana brakes on to HR cross member
Post by stinky »
DON'T use LC/LJ or you will end up in all sorts of offset trouble (I did) they pull the wheels in too far, I currently have LH/LX Discs fitted to CRS drop spindles (LH/LX stubs will fit). Not sure which steering arms though, probably HR.
cramfest
Post by cramfest »
Do I need to run the drop spindles
stinky
Post by stinky »
Nope, but it helps when lowering the car. I think HQ spindles give a lower ride, not sure about the caliper mounts though. Most pre-commodore stuff is a bolt up fit to get all sorts of combos for different characteristics.
NoMAD
Post by NoMAD »
always been a good article to refer to...
http://www.hoppers.com.au/stoppin%20holden.htm
cheers
Nathan
Foundation Member
FCOV6
Post by FCOV6 »
I put LJ dics and calipers on HR stubs and they line up perfectly, i believe they move the track it slightly but i cant confirm as i have updated to commo discs.
J
Post by J »
cramfest wrote:Do I need to run the drop spindles
Yes!
if you want your car to look awesome :P
