Anyone installed Bonnet Gas Struts ?
Sammy
Post by Sammy »
as the topic says, im keen to put gas struts on to hold the bonnet up on my FB Ute and i'd like to know if anyone else has done it and if they have, how did they do it ?
any info and/or pics would be great, i have some struts off a Commodore bonnet but im not sure how to mount them.
Regards,
Sammy.
http://www.oldholdens.com
Why do you need struts to hold up your bonnet?
I've seen alot of fb's and ek's not one with a set of stuts!
Unless you've modified your bonnet hinges?
Sammy
Post by Sammy »
yeah i am wanting to remove the springs from the hinge to give me more clearance for the Commodore brake booster, and if i remove the spring and leave the original hinge in place its perfect, but then i just need it to stay up :)
Regards,
Sammy.
I've seen a chain used. You hook it on only when you want to keep the bonnet open.
Or better yet how about pinching a rod (?) setup of a car so when open you unclip it and hook it into a spot it holds the bonnet up?
Sammy
Post by Sammy »
these are good options, but struts are more modern and hassle free :)
Regards,
Sammy.
Define Hassle free, you've still got to set them up to work :?
Me personally I prefer simpler solutions, but then again with the V6 anything but struts would be out of place...
row1
Post by row1 »
you have to get them regassed every so often as well
[img]http://i48.photobucket.com/albums/f208/row1/sign.jpg[/img]
Sammy
Post by Sammy »
by hassle free i mean once the mounts are sorted out and everythings installed they should be hassle free, except for when they loose there gassiness and the bonnet falls down :)
i want to use commodore struts (as i have 2 sets) the wagon tailgate struts and bonnet struts are the same so this should mean they can handle a fair bit of weight and also will be fairly common to find if replacements are needed.
Regards,
Sammy.
fb cruzn
Post by fb cruzn »
i havnt done this on a fb/ek but i have on a vl, try this link it might giv you some ideas http://www.walkinshaw.net/articles/articles.html
hope this helps, couldnt be to hard.
westy
Sammy
Post by Sammy »
good information there, i was more hoping someone with a FB/EK had done it, as i believe custom brackets will need to be made and i was keen to see if anyone else had them for that reason.
Regards,
Sammy.
My wifes V6 EK has a single gas strut in the middle of the bonnet , its mounted above the wiper motor on the lip and onto a bracket welded onto the rods that cross over under the bonnet skin.
It was done before we bought it and works well.
Sammy
Post by Sammy »
thats a good idea, i might have to look into that!
Regards,
Sammy.
