bonnet hinge removal?
Posted: Thu Apr 08, 2010 7:30 pm
by go_rat
What is the best way to remove bonnet hinges?
Posted: Thu Apr 08, 2010 7:31 pm
by Trev
Undo the bolts holing them on? unless you mean something else? Trev
Posted: Thu Apr 08, 2010 7:37 pm
by Bigbird
I was going to suggest one at a time, but you probably meant something else.
Posted: Thu Apr 08, 2010 7:38 pm
by go_rat
but how to undo the bottom bolt that bolts onto firewall, looks hard to get at...?
Posted: Thu Apr 08, 2010 7:40 pm
by Trev
A long extension on your socket should do it, Trev
Posted: Thu Apr 08, 2010 7:55 pm
by Devilrod
Posted: Sun Apr 11, 2010 1:00 am
by soho8
Uni joint on and extension is what I use.... Go easy if using extra leverage, you may snap the head off the bolt
pump some wd40 in there also...
Posted: Tue Apr 13, 2010 8:32 pm
by t950cat
open a beer then do it!!!!!!!!!!!!!!!
