Disc Specs.
Brodie
Disc Specs.
Post by Brodie »
Been looking for agers and cant find rear disc specs for VN/VS.
Are VN/VS rear discs the same ?
Anyone know the original thickness, minimum thickness and diameter?
I'm pretty sure min thickness is 9.5mm but cant find anything else. :?
Also HQ front discs are 25.4mm original, 24.5mm min thickness and 276 dia right??
Cheerssss.
soho8
Post by soho8 »
Its all going to vary, there wont be just one spec for a vn or a vs... irs, abs, ute sedan, 6, 8 etc etc?...
I think the standard 6cly commo rotor from vb-vs is #16????
, eg rda16, dba16 depending on the brand..
http://www.dba.com.au
From the rda site using that part number....
Std rear disc for a commodore vb-vs, which excludes all your fancies like irs etc 270mm dia 9mm thickness....Don't quote me tho, DYOR
And read this... Good info! http://www.hoppers.com.au/stoppin%20holden.htm
Brodie
Post by Brodie »
Cheers soho.
Already tried DBA etc, couldnt find anything and still cant..
They used to have a catalogue that had ALL specs of ALL rotors, it was magic but they pulled it off the net and now you gotta pay for it :roll:
I dont know exactly what the discs are off.. Standard VN type would be my best guess. Thought someone one here might of used them before and known the specs..
That hoppers site is awesome, a good read and lots a info. Worthy of a sticky maybe?
Thanks again..
Brodie wrote:Cheers soho.
Thanks again..
Done 8)
Brodie
Post by Brodie »
Thanks Blacky :)
Incase anyone else needs this down the track standard VN V6 rear discs are 279 dia, 10.5 original and 8.5 min thickness...
Brodie 8)
