does anyone know if XK XL XM XP falcon hubcaps will fit 13" holden wheels?
like these ones http://www.trueblueford.com/uploads/greyxksed_no1.jpg
i know it's sacrilege, but if they don't have &*#@ stamped on them-who's gonna know
Jimmy
okay then, its just between you and me....don't tell anyone else
lol
Hey Jimmy.
I've got a set that I was going to use on my XP (decided to stay with simple steelies and bullets instead). I'll see if they fit on my EK rims and let you know.
Cheers, Scott
Hey Jimmy
Had a chance to check out the XP hubcaps when I got home this evening. They don't fit on my EK...the caps are larger than the Holden 13s and subsequently sit quite loosely on the lugs. They would need to be modified to fit - could be done but can't imagine it being worth it, considering they are so noticeably &*#@ (most people into these era cars will know).
Basically, you could make 'em fit if you really wanted but it would take some work.
Cheers, Scott
You can do it pretty simply if you drill and tap the rim in 3 places and screw in some big round-headed screws to use as lugs for the cap to clip over.
It will take some careful measuring,but it shouldnt be too hard.
Oldnblue wrote:Hey Jimmy
Cheers, Scott
If the early falcon caps are larger it may only take a few spots of weld on each hubcap lug to build them up,then just pop your early falcon caps on.Ive done it that way before.
hmm only thing is i got chromies and don't really wana mess them up with welds or whatever. could graft whatever caps i like onto crappy EK/holden rings, but that'd still require rechroming...back to the drawing board
Hey Jimmy, I got some full 13"Foulcan caps from an American 1962 sedan that would look the shizz. Only thing is, I haven't drilled the hole in them for a bullet cause the Foulcan boys would shoot me!!! I did worse to the '52 caddy caps and the caddy guys don't talk to me any more!!!
Will try to get a pic up for you to have a look at!
Cheers Theo Z...................
i got a set of XA/XB/XC hubcaps on my 14's c's the stock hubcaps don't fit 14's, they needed some minor adjusting on the inside of the rolled lip only, i reckon they look good, nobody picks that they're F#@D. will post a pic for ya if you're interested to see.
Can I just say whilst swaying into the wrong pavillion that my first car was XP coupe (14yo) then XP Ute (15yo) mums xm coupe(16 17yo) and at 18 I bought my own driveable registered &*#@ , the next 32 cars have been Holden
Get away from &*#@ stuff , they break stupid things ! like the lip will break off the hub cap
haha just a few more ideas swimming around in my head, i just don't wanna do the same thing that someone else is doing
