Neils Frankenstein Ute
Re: Neils Frankenstein Ute
Taking Friday off from work so I have time to play with the brakes to make sure I pass, now that the engine is running smoothly I'm going to check manifold vacuum and see if it has come up if so I'm going to Tee piece it into the booster to assist the vac pump for added assistance and hopefully this will be good enough.
Latest update :wink:
Ok passed engineering but engineer still thought I was having to apply a bit to much pressure so the proviso that I pass was that take it to a brake specialist to have it checked. :roll:
To lay it out - I had disconnected the booster permanently from the manifold, fitted the extra vacuum tank (3 lt) in line with the first small one, re-bled the brakes and found a bit of air in the rear lines.
So loaded Frank onto the trailer yesterday morning and to him to a shop in Mandurah, apart from being brake guys they do 4wd's and a whole pile of other stuff, they also do the final engineering inspections for registration :crazy: so I get a phone call late yesterday afternoon from John the owner and also the engineering inspector, he says to me "what was the drama with the brakes that your engineer was going on about, brakes are fine work really well" he carried out a brake test and he will give me report to say so, this while he was doing his 5th lap of the block, he thought Frank went pretty well :lol: he also said he was happy to do final inspection for rego :clap:
Really close now :clap: :clap:
Yoo hoo you beauty Neil
mph
Post by mph »
What great news mate. Must be stoked
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Looks like his first run will be the Dunn run mate 😎😎👍
WesternWagon
Post by WesternWagon »
Nice work mate
They are great blokes in that shop
Look forward to seeing Frank on the Rd
Member : Holden Car Club WA.
:ASRF Member
CHOPPED
Post by CHOPPED »
mate
you want me to get the dunn runn trophy plaque engraved with your name all ready ????
HEY IT WASNT ME
Thanks for the comments guys, yes very close now and I am really trying hard to get Frank to the Dunn run for his big reveal :roll: :roll:
You might want to hold off on the Dunn run throphy plaque Paul there are a lot of better cars out there than mine mate.
Received approval letter from Department of Transport on Thursday :clap: :clap: booked in for what I hope is the one and only final pits inspection on the 15th if all goes well then I can pick up my plates :thumbsup: :clap: :clap:
Going to put Frank up on car stands today and get underneath and make sure everything is ok, I think I'm going to remove the external fuel pump as well, don't really think it is needed as the problem I thought I had was a timing issue with the engine not fuel starvation and it will make it a bit cleaner and pump does make a bit of noise.
Good luck Neil
WesternWagon
Good luck mate
:ASRF Member
Fingers crossed mate :peaceout:
Awesome Neil - hope it’s clear sailing
NoMAD
Post by NoMAD »
great news mate :thumbsup:
Nathan
Foundation Member
