It's bushfire season down here and there are some "unhealthy" people in our midst who like to see the local mountain afire.....
I have had to bring forward the cut and polish quite a bit earlier than planned, but have not really given it a solid bash.... just enough to get the grille back on and the car driveable if need be.....
I blocked back the outer (under headlights) baffle using 1200 & velvet soap - until the "flutter" was flattened out.
Likewise I did the same to the inner (next to radiator) but not fully down.
My preferred cutting (hand) is using Meguiar's "cleaners" and hard rubbing blocks with stockingnette bound around them.... as explained above.
The pix you see are after using these cutters, finishing off with their "Paint Cleaner" - there isn't any wax or silicone/sealant in this - I will come back in after a few months for the thinners to escape and the paint to "pull down" prior to the last block and polish....
These are the pix -
As mentioned somewhere in one of the volumes earlier - I had done this prior to the Tenterfield nats and achieved a like result - only to have preceding vehicles in rain throw up a barrage of missiles and chip/crack/dent my work.....
I went to a security door manufacturer and purchased some "offcuts" of black powder coated stainless security mesh. I was going to fit it in one length but found it impossible to fit/remove without damaging (even though I had fitted the surrounding rubber "edges") so eventually cut it into three pieces.
They were held in place behind the grille by gal wire - but this caused issues with staining the "stainless" of the grille.... so I have now obtained some 1.6 mm stainless TIG rod and will bend and cut this to shape to retain the mesh.
There isn't an overlap of the pieces, but instead made them to form butt joints - which exist at the second vertical bar from each end.
This makes the joint undetectable from the front, but a quick peek in behind the mesh reveals how it has been concealed....
These are the three pieces - this material is almost bullet-proof and hopefully will curtail any further damage - the rectangular hole size is 1.6 mm but the rod is a very tight interference fit.....
That will be all for some time...... watchers may now "stand down"....
ps - happy to answer any questions concerning this "project".... PM me if you want more....
