matty martins mild custom wagon
mattymartin
very good matty
wish i had the money to drop a car off to someone and pick it up done
if you look through the thread on thommo's chopped van somewhere in there is a link to a guy called streatneat, who's also doing a chopped van if you go through the buildup of the van he has a bit where he has put on a fuel door he says what it's off i think it was a mazda of some description, hope that helps
Hey Matty. Here's the link to the fuel door streetneat chopped van
http://gallery.oldholden.com/Streetneat ... ?g2_page=4
Cheers Theo Z...............
FB/EK Car Club of QLD.
camstuart52
- State: TAS
mattymartin
thanks guys
i'll pass on the info to joe (the panelbeater)... see what he thinks, about the 1980's mazda 626 fuel lid... with the opening mechanism.
DR, about the thingy infront of the cross member... will it be noticeable when car is back together... does it need to be changed...
thanks
mattymartin
thanks
mattymartin
go the wagons....
If you couldn't see it before my guess is it'll be fine visibility wise. My question would be does the plate its mounted on flex at all? Even though the crossmember is bolted in 2 spots I'd still be guessing you get some flex under braking and acceleration. If you have an original crossmember with outrigger maybe look into swapping them. Ask the guys doing your car what they think. if they have played around with a few early holdens then they will hopefully give you a no bull sort of answer.mattymartin wrote:DR, about the thingy infront of the cross member... will it be noticeable when car is back together... does it need to be changed...
thanks
mattymartin
mattymartin
mattymartin
Some yes and some from Moon. The new ones Johns have are really nice (new supplier), to the extent if I had spare cash I'd be swapping mine
The slide straight on and have a grub screw to hold them. The only mod is a slight enlarging of one to fit the wiper switch.
captainbill
Thats what he's after Captainbill. If you look at Matty's you'll see the left the HR one on.
Although Matty you will probably need to find the original bracket to bolt the outrigger and its rubber back up if you do swap it. Just another piece to add to the puzzle...
