Just a picture of something I’m playing with
Re: Just a picture of something I’m playing with
What is with the threaded ports in the exhaust primarys?
Temperature sensors I am guessing....Errol62 wrote: Thu Dec 30, 2021 4:32 pm What is with the threaded ports in the exhaust primarys?
Yeah temp sensors go in them on the engine dyno... the next part of the puzzle is the common plenum air box and cold air intake... looks like the dyno day is happening on the 7th fingers crossed it might be back in for all Holden day
Great work mate , looks the goods.
FB-Special
Big block 161
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Big block 161
Holley sniper EFI.
- State: SA
gledge wrote: Fri Dec 31, 2021 8:42 am Yeah temp sensors go in them on the engine dyno... the next part of the puzzle is the common plenum air box and cold air intake... looks like the dyno day is happening on the 7th fingers crossed it might be back in for all Holden day
Great stuff, look forward to seeing the car close up
Mm mm hope so Glen. Get cracking!
One step closer
Tomorrow’s the day to bolt all this together and see what happens
Looks the schizz Gledge, here's hoping you see the numbers you are looking to see
Let’s just say it all in bits again
I hope its, you pulled it down and not the dyno chewing it up !!!!
The red engine has its limits, the big one is hard revs where the crank will pull on the mains and split the bores horizontally.
Try and keep the revs down if you can.
Bugger
