it was $5100 paid 2,550 as deposit & 3 weeks later paid the rest & $170 delekdave1962 wrote:Now that looks sweet can I ask what they charge and delivery time ?
Tigers V6 Conversion
- michaeljohn1234m
- State: NSW
Re: Tigers V6 Conversion
- michaeljohn1234m
- State: NSW
some more photo's on what fits and what does'nt fit
the air con does'nt fit, there's only about 2" of room & that's the biggest downer, i was just about to buy the Vintage air set-up
I kept my Extractors from CRS from when i had there HR front end but they don't fit on the drivers side, the power rack is in the way, i'll get Pats one
I kept the Gearbox Crossmember form CRS i had to elongate the bolt hole and cut some off for it to fit right, so thats right
i'll have to go with the new 7" power booster as there's not that much room for one
It does sit sit nice and i'm happy with it
- michaeljohn1234m
- State: NSW
found some photos from when i was doing it up in 1999-2000
thats sid doing the crap jobs
and the donor car
and some when it was finished ready for rego
and the donor car
Looks cool as, nice job
- michaeljohn1234m
- State: NSW
Well spoke to Pat about the air con and he has a bracket for it. (using a VS air con) that was good news, And i spoke with George (Alien retro columns) and he's starting to do the EK auto columns,I just have to work out the length,as with Pats front end the column stops at the fire wall,and a knuckle goes straight down to the rack,so the wire must start just inside the cab.so i have to check this out before i order one ( such fun ) here it is on his facebook page
gnomester
I've been paying close attention to your build and it has inspired me to do as much as I can to get my build moving forward.
Your're like a pathfinder, sorting and documenting the small and not so small, problems like the air con needing a bracket and that cool steering column
If my build is close to the quality of your origional EK mod it will make me happy
nes138
Hey mate, Nice ride.
What caliper / booster / master combo you running?
- michaeljohn1234m
- State: NSW
Hi nes138,I'm using VS caliper's for now,i'm still looking a what booster /master to use , most likely a 7" combo like the one on brodie's EK page 9 (not the datsun one) further down the page.nes138 wrote:Hey mate, Nice ride.
- michaeljohn1234m
- State: NSW
Thanks gnomester and i look forward to watching your buildgnomester wrote:I've been paying close attention to your build and it has inspired me to do as much as I can to get my build moving forward.![]()
Your're like a pathfinder, sorting and documenting the small and not so small, problems like the air con needing a bracket and that cool steering column![]()
- ekdave1962
looking great, i just finished my v6 conversion took me way longer that planned 12 mth but i also reprayed car and added full vn loom ( for some stupid reason and the lx front end)
have you planned what u are goign to do with the speedo and ecu connectors i used the crs t connector and it giving me nothing but grief it strips the nylon treads on the gear box very easily and im not getting signals to speedo seem as if the drive doesnt connect to box to well .. am looking for alterate ideas either concet speedo direct to box and use a manual tcc lock up or connect tcc to box and change speedo for a gps type one
nes138
That legal?ekdave1962 wrote: change speedo for a gps type one
- ekdave1962
sure is mate just had his 34 dodge rat rod enhineered and registered with one
- michaeljohn1234m
- State: NSW
Hi ekdave, no i have'nt looked at the speedo as yet,still looking at the brakesekdave1962 wrote:looking great, i just finished my v6 conversion took me way longer that planned 12 mth but i also reprayed car and added full vn loom ( for some stupid reason and the lx front end)
- michaeljohn1234m
- State: NSW
Well i finally got my wipers working,I had the wrong wiper motor that was the problem,so i got the right one
and this one fitted great
used my other plate to test it out with some new holes
had to grind a small bit as it was hitting the hole it sits in
and just put it back together
wireing was ease thanks to http://fefcholden.org.au/forum/index.php?topic=18113.0
and all is fine
and all is fine
nes138
Good to see you worked it out mate.
