EK morphs into pillarless Coupe .
thanks devilrod ,you know ! Every time i discuss color combinations and trim color and designs with my girl ,she just keeps describing your car
As a matter of fact she despises orange ,and gold is very close to that .
Ratbox i was throwing out the line with the whole looks good but isnt functional twist ,will have to use better bait next time .
- Sputzwagon
Cool!Harko wrote:thanks devilrod ,you know ! Every time i discuss color combinations and trim color and designs with my girl ,she just keeps describing your car
Choosing the right colours are a make or break part of any project. Good luck! The right shade of gold should be fine. Aim for more yellow and you should be safe (well in staying away from orange).
Smooth customs
Harko wrote:Its a body swap . Just like a commodore on a 4wd chassis .
The roof chop goes under the roof chop requirements as you know .
and the big block under the power to weight ratio .
Jas if you can weld its fairly basic , Have a lay under the car and have a think then ask any questions you want.
Years ago I did several cars like this, with no problems
Reciently I went through all the engineering and mods to do a very similar build to suit a NSW registered car, it kept being listed as an ICV.
Spoke to four different engineers and they all gave me the same answer.
But if you can get yours registered like this, go for it.
This doesnt go anywhere neare fitting
Will probably fad the engine mount blocks on the weekend and mod the firewall .
and it doesnt drop as much as expected either
And heres what I was blabbing on about with the headlight area moved to correct the flow , The left headlight flows back evenly , the right headlight is original and you can see it curves as it flows back
Also that small cut allows the peak along the top of the guard to become closer to square
that's how the 308 conversion started in the ute stuck a 283 in the engine bay and didn't want fenderwells new a mate had a 308 in an EH with manifolds and the rest is historyHarko wrote:This doesnt go anywhere neare fittingWill probably fad the engine mount blocks on the weekend and mod the firewall .
Rat,ratbox wrote:glad yor custom dash idea is different to the one i have
yors is better than this one but here's one i prepaired earlier![]()
I can't see why! if you went to that much trouble smoothing your dash, why didn't you fit the radio in the middle..............................
Just a question.........Not a debate
EK283 wrote:Guys,
To make the chev fit nice and low you need to recess the HR front end.
The firewall drivers side neeeds to be pushed back slightly as well.
Stick with the chev Harko![]()
Go the CHEVY Harko!!!
