WRAY T96 SUPERCHARGER refurb and install
Re: WRAY T96 SUPERCHARGER refurb and install
It will need to be a hefty spring.
Spring tensioners are normally used with timing belts ("gilmer belts") where the faces of the belt teeth provide grip. For vee belts, you rely on friction alone... and hence need more tension.
Yep - no way to may it work anyway - so with the improved rigidity belt plus improved rigidity tensioner arm plus a slotted pulley Fred will turn up it should be okHarv wrote:It will need to be a hefty spring.
Finally home in time to get to the post office......Errol62 wrote:Just pm me postage details. Yours gratis.
Thanks mate - I’ll get those screws sorted if your keen on stainless?Errol62 wrote:Finally home in time to get to the post office......Errol62 wrote:Just pm me postage details. Yours gratis.
Deal Rob
Looking at the choke connection to carb the stock cable i had which was a rares one I think is about 6 inches too short and looks about same as the nos one I have - any suggestions on one thats a bit longer or do I go the bike cable outer and solder on a longer core?
Choke cable: HK-T-G?
Bonnet cable
Picked up a Hktg choke cable (thanks Rob) and cut and shut the ek knob onto it - should work out nicegpi wrote:Bonnet cable
Choke cable done
hurry up , we want to see it doing a skid !!!!
Yeah two skids if you’ve got the true track installed.
Tru trac is in - still waiting on the final blower tensioner arm and i have to finish the throttle linkage then it’s clutch droppin time
This is what the new tensioner will look like - bit of machining to go yet plus the twin track idler to stop the belt shuffle
I fly home next Friday into a 2 week lockdown at home , hoping to get some progress on the red rattler done while i am not allowed to leave the house .
