What are the caps on the pontiac made from ?
Life & death of a Custom
I had used a wagon fuel tank and made up a filler door from sheet metal, a magnetic sterio cabinet catch was used to keep it closed, (high tech stuff) and the back of a speedo housing was welded in for the recess of the tank filler neck.
This was about the time I started making those bullet tail lights (1994) as a set can be seen in the car.
It was also decided not to use the bubble skirts as they didn't suit the lengthened tail. Luckily enough, I was soon to meet ace metal man & fellow custom nut Paul Kelly, (that was the Cararra swap I think) and was soon to swindle him out of a set of his neat-o cruiser skirts. Hey Paul, was that set no. 1.
The car in the background was a 48 Buick that I got as a sedan & turned into a 2 door roadster. Sadly never finished it tho, new house .
If the car was normal length the other car probably would have missed
That is the best continental kit (conversion) I have ever seen, and I've seen some ugly ones.
Build another one, go on this is grouse, Trev
Smooth customs
You left a little bit out about the Cruzin Skirts.
I spoke to Rob at the swap and told him I was starting to make up some bolt on custom parts for FB EK Holdens, and was looking at doing Cruzin Skirts
Rob had an FB EK wagon parts car sitting around that he let me use to make the master patters for the skirts on.
Am sure the ones I did for you were the first.
- State: NSW
- Contact:
A great thread Rob. A 'history' lesson at its best. Thanks for sharing it with us all.
regards
Stewart
regards
Stewart
Pity that something with that sort of history ends its days like that
Brootal
- Contact:
Very cool story. You can a lot of US custom influences in that car, way ahead of what most Aussie guys were doing with their early Holdens in the 80s and 90s.
J - that roof scoop was a feature on '58 Chevy Impalas and became quite a common custom touch in the late-50s. That (I dare say) is the inspiration.
The high-mount brake light? Well... that's just sensible. Doesn't look like it helped... although you never did get hit up the arse, did you!
fb cruisin
- State: NSW
