OK as promised, there's enough skin to do some more today.......
Upol Bar Coat isolator - about one third of it was "stuck" to the bottom of the can - manufacture date was October '07 so it hadn't been sitting too long - must be stirred up thoroughly - watched it start to settle after 30 minutes in a glass jar.......
Goes on great - no spider web - does not need thinning and is one pass only.
Unlike 1K etch - this is a solid coat.
It has to be left for around 1 hour before applying primer/surfacer.
I am very, very happy to state that this primer surfacer (with hot thinners) did not get through!
One word of warning - don't panic when you can't clean up with solvent - it cleans out with methylated spirit - and very well..............
I coated everything intended for acrylic gloss which I had sprayed Tie Coat onto as below...............
After the required hour, two medium coats of primer/surfacer were doubled over, twenty minutes later I hit it with another two - and checked..... not blisters - guess I've got nearly a litre of isolator for something - it doesn't come in a smaller package - hope it keeps.......
This (again) and you must be as tired as I am of looking at this in primer grey....... is where it's at - again......until guide coat - blocking back and finally - top coats......
Whilst in there - I removed the rear seats and fastened the panels down - being ply - I can break in if I lock the keys in the boot - don't laugh, it's been done so many times- I'm sure the general had this in mind when he fitted panels instead of steel.........
All the interior of my bus has been treated, fishoiled, primed and many, many, many coats of hammered metal epoxy - I have had a "play" with those steel rings used to hold the upholstery in place on the seats - you won't believe wher most of your squeaking, clunking and crunching noises come from - I replaced ALL those rings in both the backrest and base with cable ties - seats back in and absolutely silent - the only noise is where the cushion rubs the vinyl on the arch covers............
I fitted "Moonwalk" matting to the underside of both - those springs are now insulated from any metal - the tape you can see in the pic below is just to hold the matt in place until the small spots of adhesive dry.
I have also fitted this "Moonwalk" under the arch covers - this will make it considerably more comfortable for those in the rear when three rear seat passengers have to be "good friends" for a lengthy trip.......
I have used this on the entire floor area and find it absolutely great - not only as insulation, but it also "grips" the shiny surface of the epoxy and prevents the carpet "creeping" when it it subjected to people's movements in the vehicle.
oh yes - the pic....
today is another block back - and a few little chores - hopefully, we'll see some colour (black is not a "colour") mid week and then I can close the lid..........'til next review.....
