That also explains why I had to slightly bend the brake lines to get the U bolts on. It seemed strange at the time that it didn't have enough space.
HR manual images attached. Exploded and installed. (Aren't pictures great)
I can't find any mention in the manuals on how to remove the bump stops from the EK frame.
Does it need to be done ?
Can't I have both upper and lower ones ?
If not, is it pushed in, screwed in, attached at the top ?
Thanks DevilRod I'll check him out, should be able to freight to Brisbane.
Couldn't find any mention of U bolts being used on HR vans and utes but the manual did say that the 2104 and 2106 had 2.25in wide rear brakes and others had 1.75in. The lining was also slightly longer.
I think I'll just go with the bolts, that was how it was designed. Will probably need some new rubber isolators.
Measurements for the bolts would be great, then I can get that part stable. Thanks.
