accelerator pedal
Post by mrs ratbox »
i've used datsun 1200/120y pedal with a little bit of bending used the same hole as others have mentioned and a xd &*#@ v8 cable when used with a holley whole job from start to finish takes about an hour very easy
HEMI
Post by HEMI »
Here's a pic or two
[/img]
FOR SALE...VAN, TRAILER, CONVERTABLE..0400568049
Sammy
Post by Sammy »
neat setup for a strommy!
Regards,
Sammy.
http://www.oldholdens.com
yeprat1
Post by yeprat1 »
thanks for the pic hemi i was actually thinking why didnt speed shops come up with this conversion could u please tell me though what are those attachments u have used there supporting the cable where it joins the pedal thanks troy
stinky
Post by stinky »
I might have to give this a try on the FE, it looks like with a bit of "creativity" you could avoid the cable going inside the car altogether.
HEMI
Post by HEMI »
The part you are talking about yeprat1 is standard L300, the fitting on the carby is standard choke fitting turned 90 deg.
Looks good if going for a clean simple engine bay and cheap too cost a whole $10
