Need help with what front end to choose ?
Kingaz
motor
Post by Kingaz »
Like Trev said its amazing how quickly the cash starts to run out as many members on here including myself can agree too!
First option would speak to an engineer on building guidelines for the FB EK as gathering the right research is critical for any build, you may just find out how expensive it is to do such conversions.
If the car requires panel work, paint, trim suspension brake upgrades other various things that pop up the budget may be gone before motor selection is even chosen
By all means im not trying to put you off i just remember when i brought my ute i had a $6K budget (doing everything ourselves) and a 9 month time frame... over 3 years on still not registered and well over three times initial budget and thats with a stock grey.
If your cruising at night and just want to run people next to you although a 8 sounds great a worked 6 can be just as quick
Good luck use the people on the forum and their experiences to obtain the best info on what works and cheapest alternatives
Adam
FB-EK Holden Car Club of Victoria
FB MAD
Post by FB MAD »
I wouldn't want to spend $22000 on a car to drift........ most likely into another car or a tree.
Not to mention all the time and effort you've put into building a $22000 car.
Start doing things like that in an old car body and thats what you'll end up doing.They are just not designed for high po work.
If you have the same P plate laws as are here in NSW you'll find you won't be able to drive it with a high power engine anyway.And if you can, the insurance for a P plater in a modified car will probably cost you $22000 a year, that is, if you can find a company that will insure you!!
You need to speak to an engineer first before you buy or do anything.They can make or break any dreams you may have.
You need to do a lot of research and costings before you start doing anything and once you have the dollar figures, double that number.
Whack in a Toyota gibbaly goog 4AGZEet758abcdefg engine into your Camry and have some fun with that.
thropzed
Post by thropzed »
Why not check out the possibilities of fitting a Jag series two power steering front end. They can be engineered and give you all the drop ya need without losing suspension travel(much like LH torana conversion) Set up all your driveline on the floor of ya shed, mod where nessesary and fit. Interior can come at a later date as I'm sure you don't need to have a flash interior going sideways. Body work and engineering will set ya back most of ya budget, but in the end you'll have a car that ya can give to ya kids.
Cheers Theo Z...................
FB/EK Car Club of QLD.
jazzar02
Post by jazzar02 »
lol FB mad we rolled the camry on it's side trying to drift 120kmph around a corner. but i just want a car that people would say "wholey shit it's a EK" when it coming sideways to them.
Car 1:
1961 Holden EK restoring in progress
Car 2:
1990 Excel, ex Option audio demo car.
Car 3:
1927 Dodge fast four pickup.
Car 4: 1987 Nissan HR31 GTS-X skyling coupe
Car 5: 1979 Datsun C210 skyline with a L20et conversion
FB MAD
Post by FB MAD »
Mate it won't be going sideways.
I'll be rolling over. :cry: :cry: :cry:
Kiss your $22000 goodbye.
jazzar02
Post by jazzar02 »
yeah i surpose i don't want another car to roll. I think i wall just do it up to a street beater. As i know with a fully modded grey motor they can do a 1/4mile in 14seconds with the right parts.
Car 1:
Car 2:
Car 3:
(AUST)Mod
Post by (AUST)Mod »
Will go faster for way less with a red motor 8)
Craig
Post by Craig »
SPL camry wrote:As i know with a fully modded grey motor they can do a 1/4mile in 14seconds with the right parts.
:roll: :roll: :roll: after you spent a shit load and even then :roll:
Better dead than red
EK, the VN of the 60s
oldnek
Post by oldnek »
thropzed wrote:Why not check out the possibilities of fitting a Jag series two power steering front end. They can be engineered and give you all the drop ya need without losing suspension travel(much like LH torana conversion) Set up all your driveline on the floor of ya shed, mod where nessesary and fit. Interior can come at a later date as I'm sure you don't need to have a flash interior going sideways. Body work and engineering will set ya back most of ya budget, but in the end you'll have a car that ya can give to ya kids.
Theo, Thats a great idea, but when I looked at one of those there 1.2 inches wider in track. So you can't quite clear the guards.
thropzed
Post by thropzed »
John,
I know a guy up here that narrows them and fits to what ever application he needs. I know we did our 47 Fargo with one and the differance in drivability was fantastic. I might even think about one for my next EK! SHhhhhhhh! Don't tell the wife!!!!
Cheers Theo Z....................
SPL camry wrote:yeah i surpose i don't want another car to roll. I think i wall just do it up to a street beater. As i know with a fully modded grey motor they can do a 1/4mile in 14seconds with the right parts.
You better start with a cross flow head (repro one $5500) there goes a big chunk of your money :shock: . Trev 8) .
Craig
Post by Craig »
Yep and thats for a bare head no valves ect and you need a right angle distributer custom side plate custom intake and exhaust manifolds a lot of coin before you even start on the rest of the engine
FATBOY
Post by FATBOY »
theres a guy in queensland that makes a new chrossmember for jag front ends im goping to use one in my 28 chev tourer im building $750 for the chrosssmember and you just bolt up the rest of the wishbones .
regards fat
lilow in vic do a independent front end $4800
Rod tech $4300
Post by mrs ratbox »
gardener's do a fancy "bolt in" front aswell around the $4,500 mark from memory
you want to drift it :?: it WILL do it especially if set up to do so, my mates FC is set up for drag racing and does a great job of drifting :D
jazzar02
Post by jazzar02 »
Well i was thinking of going a red motor what (aust) said, it will be cheaper to go with a red motor. But isn't there 2 sizes of red motors? What one will be the best for performance and strength ? Also i was thinking for a rear diff, getting a VN diff with calipers and Hubs. If a 202 red is the go i found this red engine on Ebay and it is like 40kn from where i live so it's gonna be a bargin if you think it would be anygood. here is the link
http://cgi.ebay.com.au/HOLDEN-RED-MOTOR ... 7C294%3A50
Car 1:
Car 2:
Car 3:
