Bwahahahahahahah nice one Mick. Chev looks good! You'll get a good price when you go to sell that now!
i hope so only bought it to take to canberra and resell hope to get 8ish for my trouble, it's just a closed door paint job but does the trick
got to get some more photos as it's now closer to the ground
8ish? That might be enough to get you a rusty EK, Mick
car had been sitting for a long time first it had blown head gaskets, then i was stumped as the radiator seemed to take alot of water to fill and when released would empty quickly so didn't seem to be blocked, i end up changing the water pump and the radiator and the problem is solved so i don't know which it was i'de say the radiator as i've put a filter in the top hose and i'm collecting quite a bit of crud/scale, mine may not have been blocked but might not have had enough cooling capacity as the one i put in is a H/QJZX big 4 core aircon radiator and when i had the heads off it's a 307 block but been bored out to 4"+40 which is quite a bit
Mick wrote: stalls when put into gear but can drive just a bit fiddly
Sounds like a vacuum leak between the trans & manifold line???
I like this beast Mick..
Scotty.
funny you are not the first to say this when it cools down a little i'm going to dissconnect the vacume line to the modulator and see what happens in park and neutral it'll sit there and idle fine but drop it in gear nad you have to fiddle with the gas pedal to keep it running it won't idle, drives and runs fine other than that does downshift hard though when slowing for a corner etc
yeah i like it too, but i have to sell it can't afford to keep it plus the funds from selling it WILL go into the austin
