gargling engine
JimmyJazz
Re: gargling engine
gah. went for a drive today and it worked for a bit then chonked out. same problem. looks like someone is pulling a carby out and manually cleaning out the jet and fuel bowl.
Re: gargling engine
Have you got a fuel filter? If so does it need changing or fit one preferably before the pump to avoid clogging that up too.
JimmyJazz
Re: gargling engine
wd40 clean of everything in the carby and shes running even more smoothly than before all the silly buggers began! replaced the fuel filter - is it worth having one on either side of the pump, i've seen it done but i wonder if it's not overkill? cheers again guys
Re: gargling engine
Before the pump should be enough.
