Twin carbies????
OldMan's Lacky
Re: Twin carbies????
Post by OldMan's Lacky »
I owe you an apology Dr Harv!!!! :oops:
Found this on page 91 of your guide where it talks about the decrease in pressure when adding an additional carb:
"Note also that in fitting venturi sleeves, the signal sent to the main metering system is much stronger (i.e. the main metering jet gets “sucked on” harder. This can lead to the main metering system running rich. When fitting venturi sleeves, the main metering jets will need to be decreased in size to account for this(see tuning notes below)."
So my next question is has anyone on here fitted venturi sleeves to their BXOV-1's when changing to a twin carb setup or have they done without them and just reduced the metering jet? Sorry if I am sounding uneducated ... probably because I am :lol:
ash
Post by ash »
Yep I fitted them, did not try the carbs without.
I am using 46 main jets and the mixture is very good. (maybe very slightly rich, beats being lean though)
MeFB
Post by MeFB »
OldMan's Lacky wrote:My old man always says 'give credit where credit is due' ... so you will forever be known, to me , as Dr Harv :wink:
Dr Harv - can always be relied on to stick the right needle in the right orifice :shock:
:arrow: :D
Alan
OldMan's Lacky
ash wrote:Yep I fitted them, did not try the carbs without.
Didn't realise I missed your response. Thanks Ash!
