cleaning out fueltank
FB MAD
Post by FB MAD »
superstock wrote:Hi Dave68,About 8 years ago cut 2 large home gas bottles in half to use domed ends for large compressor tank. This method works well with fuel tanks to that have just been emptyed. flush with water 5 min empty out connect vacum cleaner size hose to exhaust of another car insert into tank you wont to cut or weld. Run exhaust gases into tank for ten min
before you start. when ready leave motor running while you cut.Many thanks wayne.
Not a bad idea :roll: , have heard of blokes using an inert gas supply to the tank/cylinder ( Argon gas from memory ) as it depletes the tank of available oxygen for combustion/explosion.
