Daves EK
- ekdave1962
- ekdave1962
Re: Daves EK
hi there guys been a while since i posted on my car ..
have started a re built of the girl using Torana front end and V6 motor
attached are a few pics ..
i have a questions for experts on the forum .. i have fitted the motor with enough clearance to fit the VN sump un modified but it means the engine will sit a 15 % sloping back wards (see pic) will this angle effect to running of motor ?
engine angle
sump clearance
engine angle
sump clearance
- ekdave1962
Re: Daves EK
a few more pics of the project just to let ya know i havent been goofing off
the wiring what a job used complete vn loom and relays fuse box etc
big brakes au 2
fitted a vn column it take the ek wheel with a small packing bush to operate indicators etc
picked up the CRS sump today ..
and speedo tee
big brakes au 2
and speedo teeRe: Daves EK
Dave,
Going in a different direction hey ?
I'm pretty sure Malcolm had some vibration because of the angles between the motor and diff.
Not sure how much they can lean but 15 degrees to me just looks to much. What was it in the donor car ?
Lots of spagheti hope it all works
Good update.
Good update.
- ekdave1962
Re: Daves EK
yeah /greg im not to keen on it not sure what the engine angle was in donor vn, but with out major tunnel mods that was the best i could get, if it doesnt work out too much vibration, then i will be a tunnel mod but thought i give it a go as see how bad it was .. ps your cars coming along slowly
Re: Daves EK
15 degrees sounds a bit much to me too , and why are yuo using the complete harness , are you using VN guage cluster , air cond , etc ?
The VN has an engine harness that is pretty simple to modify to a stand alone engine harness , then you can use your FB/EK harness for all the other bits such as headlights, indicators , guages etc.
- ekdave1962
Re: Daves EK
i have actually got the angle down to 8 deg using red motor mounts , as for the wiring i agree blacky but the ek wiring needed to be re done so thought id use the complete vn loom .. and it was a head ache, almost tossed it a few times as it would have been easier to wire it from scratch but got it all sorted so thats history now ..
- ekdave1962
Re: Daves EK
ok guys a few more updates on the project
had an engine bay fire whilst testing the V6 ,, split in fuel line ,, was a scary moment thought i was going to lose the girl ..
[IMG]http://i221.photobucket
.com/albums/dd314/ekdave1962/fire1.jpg[/IMG]
all repaired now and painted gloss black
LH frontend installed and all seem to be going well
this is not the ride height ,, but now with spring and shockers fitted there stuff all bounce in the front end may be a till to stiff
[IMG]http://i221.photobucket.com/albums/dd314/ekdave1962/fire1.jpg[/IMG]
Re: Daves EK
Looking good Dave
Re: Daves EK
Would love to do this but that wiring looks too scary for me
- ekdave1962
Re: Daves EK
trev the wiring for the motor side is not bad ,, it was silly me deiciding to use the fun vn loom and held me up for ages trting to work it all out ..
- ekdave1962
Re: Daves EK
well its coming to an end ,,
on reflection i think i would have gone the Wallingtons front end for $3500 bolt in . when i added up cost of lh front end and the work , bushes $400, shockers and springs $250 , csr sump $650 , hopper brakes $1200 and theres will used std vn sump and comes with coil over and commodore brakes ,,
still was a great project and learning experience just need to touch the paint up and re assemble the bling and i should be cruising again ,,
added a programable ecu as well
the old spring compared to new ones not sure what the old one where but they where rock hard nnext to no moverment so went for 30 mm lowered could have gone 50mm
Re: Daves EK
Nice one Dave
, hopefully you have more luck than you had with the VK motor
