Project 2.
Re: Project 2.
Many thanks for all the comments and ideas. If I stick with 13inch wheels, will a standard hr disc front end work ok if I can get one?
Project 2.
You have to run the later centres, HD HR or Torana/ROH (these require the later wheel nuts with steeper taper. Don’t mix and match as the offsets vary between models. With these rims hub caps will stick out further giving less of a dish appearance. Easily overcome by running wider rims, six inch all around or sevens on the rear. Just need a stock 4 1/2” rim for a spare if you want to fit it in the spare wheel well. Five inch Torana rim may fit with a skinny tyre. Best to make sure they all use the same taper wheel nut.
Re: Project 2.
Thanks Clay,
Bought the new one undercover today. Nice tailgate and spare tyre door (with key) if I say so myself. Getting busy in the shed. Kate's Beetle is now an outside carImageImageImage
Re: Project 2.
Aren't you having fun!
Re: Project 2.
Just like you Clay! I wish I wasn't so cramped, but it is what it is.
Re: Project 2.
Brett027 wrote: Sun Feb 07, 2021 5:50 pm Just like you Clay! I wish I wasn't so cramped, but it is what it is.
Cramped is a sedan, wagon and three kids cars worth of drama jammed into a single car fibro shed :mrgreen: :lol:
Re: Project 2.
Yes Harv, that does sound a bit tight.
Re: Project 2.
Looks like that shed has been extended once, might be time for another 8)
Re: Project 2.
Yes I did that extension for Wilma. It would be too low to go out any further and wouldn't get aesthetics committee approval. 😁
Just bought an HR disc brake front end. Woohoo😀
Re: Project 2.
Well done. Got all the bits? You want the draglink and pitman arm if sticking with worm and sector steering box. Rotors, calipers and backing plates, pins, anti rattle springs hose brackets?
Re: Project 2.
Yes I think so Clay. Had previously bought whole HR draglink assembly including pitman arm but this comes with that setup. Brakes are complete and working so I think all ok. Only thing I know I'll have to do is move engine mounts a bit - they are very forward. Comes with extra brackets to mount engine back but probably cut off and move. Pick up Saturday. That's pretty much the necessary bits now for red motor conv. Tail shaft length will need to be sorted too. The powerglide one that was with the ute is short and wrong yoke for 4 speed. Big dilemma now as was going to put reco grey motor and box in this one and do the fancy stuff in Project 2: but think I'll go straight to red now on this new ute now.
Re: Project 2.
Original HR position is well forward yes. They should end up right at the back but dummy got and tack in place is best. As Neil says zyou can get blanks from Mr Mallaby on FC site.
If it is straight out of a HR you replace the front outrigger with an FB EK one, or you can mod the hr outrigger.
Re: Project 2.
Thanks Clay. Came out of an EJ so outrigger in place.
Re: Project 2.
More questions: 186 currently has auto so need to convert for my M20 4speed. Do I need a 186 engine flywheel or will any red motor one do?
Re: Project 2.
Any Red six flywheel Brett. Or blue but they are lighter due to the fully counterbalanced crank.
