All fixed now.
It ended up being the fuse holder.
The one that had the cigarette paper getting it to work.
Had power on one side but not the other, even though the fuse was good.
Ended up pulling it all out and cleaning it up, replaced the fuses and all the connectors.
Just too much buildup on the metal contacts, not letting the power flow.
Indicators now work again, and the dash indicators are also working correctly. All back the way it should be.
Need to address the interior light one day, but it's not a Roadworthy issue.
Inside dome light works when the doors are opened, but only works when the ignition is turned on !!
Wonder how they wired that one up ?
