EK-2106
ipg
dont worry guys, the pics were taken before i had had a chance to inspect the job. all the primer was removed as was paint in the back.
i had feared worse for the rust situation but things turned out ok...
its currently getting the following:
inner sills
outter sills
floor cross braces
rear sub frames
inner sills
outter sills
floor cross braces
rear sub frames
ipg
ipg
- ekdave1962
nice
ipg is that power coated of sprayed .. looks better that new ..
D
D
ipg
- ekdave1962
power coating
ok what did they sting u for coating the fronted .. ipg ?
Upper wishbone pivot shaft bolts ( HR series ) - 50 ft/lb
Ball joints - 70 ft/lb
You weren't specific on the lower control arms so I'll give you the lot and you can work out which one you need.
Upper and Lower wishbone pivot shafts in crossmember Min - 50ft/lb
Max- 250 ft/lb
Upper and Lower pivot shaft bushes - 60 ft/lb
From Gregory's '48 to HR shop manual.
Terry.
Max- 250 ft/lb
Terry.
