Triple stromberg linkages
PEARO
State: QLD
Post by PEARO »
As the title suggests I'm wondering if and where I would buy a set of linkages for triple carbs
Hi Rob,
Are you after linkages that go straight through or off the side of the manifold?
I've bought stuff from Hardimans...http://www.redlineauto.com.au/
regards
Stewart
PEARO
State: QLD
Post by PEARO »
Stewart,
The manifold I have is a "Cain" triple downdraught stomberg to suit a red motor, so I will need the straight through type of linkage, also can you advise on cost.
Rob,
I only had to buy a ball joint assembly and a throttle rod it came to about $40 approx. Mine isnt a straight through.
have a look here as well http://www.speco.com.au/acccarbfit.html
also Rares might be able to help.
regards
Stewart
