Ammo's Ute
Re: Ammo's Ute
My fronts were rubbing with 195/75R 14. Put on 195/70R 14. No rubbing. 5n 6” rims.
Re: Ammo's Ute
it's a fine line have the wheels you want or the ride height you want, someone said to me once when i said being so low it's a shit ride well lift it up, my response i wouldn't want the car if i had to look at it lifted up 8) :lol:
Re: Ammo's Ute
Any updates on this Roger ?
Wrongway Roger
Re: Ammo's Ute
Post by Wrongway Roger »
An up date as requested.
With a heap of help from Blacky, there is working power windows nows and before you ask, yes we used 2 relays in each side.
Tested and have the pass tick. Also update the white board to smiley face on the wiring line. :D
To me it was a little outside of my skills but with Blacky's help, all good.
Next is to finish the interior lights and puddles lights, put the door cards back on. :thumbsup:
I have the rocker switches in and wiring laid out.
At last some progress.
Cheer, Roger
rocker switches.jpg (137.09 KiB) Viewed 6322 times
Re: Ammo's Ute
Wrongway Roger wrote:An up date as requested.
Cheer, Roger
And here’s a picture ……..
Re: Ammo's Ute
Hi Roger
What type of heater are you using mate
Wrongway Roger
Re: Ammo's Ute
Neil, I think the heater is out of a HR. Single speed fan.
Now iI need some help wiring up the handbrake warning light. Yes
i can tie my own shoelaces but electrical wiring requires wizard grade thinking. :oops:
I'm using a HQ style handbrake which has single wire.
The warning light will been one of the idiot lights but update engraving,( P )
LH Gauge.jpg (210.28 KiB) Viewed 122 times
Re: Ammo's Ute
HQ style earth through the handbrake switch so power to the globe, then earth wire from other side of globe to switch.
simples.....
Re: Ammo's Ute
Blacky wrote: Wed Aug 19, 2026 5:17 pm HQ style earth through the handbrake switch so power to the globe, then earth wire from other side of globe to switch.
simples.....
What no relays??? :lol:
Re: Ammo's Ute
So I would like to add that the power wire should come from an ignition source and fused, probably the same circuit as your fuel gauge or something that comes on when the ignition is on.
As Blacky has mentioned power to the globe then out to the switch wire, this will ground the globe for the power to run through.
This is similar to the way horn buttons work, negative switched.
Re: Ammo's Ute
In the Shed wrote: Wed Aug 19, 2026 6:53 pm
Blacky wrote: Wed Aug 19, 2026 5:17 pm simples.....
… and at least three diodes 😂
Re: Ammo's Ute
Like this - piece a piss ImageImage
Wrongway Roger
Re: Ammo's Ute
I bench tested the power to globe suggested setup but the idiot light are grounded via to gauge cluster.
idiot light earth.jpg (96.43 KiB) Viewed 34 times
I would need to insulate the globe holder then run a wire to the handbrake switch.
Does this sound correct ?
Re: Ammo's Ute
That mounting plate is usually +ve from ignition switch, not grounded. Normally wired to ignition on and bulb wires go to ground through temp, oil switch and gen. If you changed what you ha ve back to standard, your handbrake switch and light would work as they were designed.
Wrongway Roger
Re: Ammo's Ute
Brett, that makes so much sense. I thought I was being clever grounding each gauge cluster.
There are several gauge clusters in the shed but all the gauges have been removed so I check the crusty wagon, not that I should have doubted you.
Tomorrow I will grab an ignition wire to power up the gauges if my back holds out. I'm too big to be bending over or putting my boof head under the dash.
Thanks to everyone for your advise. The forum is a winner.
