LS1EK
Bushcreature
Re: LS1EK
Post by Bushcreature »
Amazing work!
WesternWagon
Re: LS1EK
Post by WesternWagon »
look Killa
Member : Holden Car Club WA.
:ASRF Member
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Some more progress, one side of the engine bay all smoothed out. Will be going for a satin black finish.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Been scratching my head on how I was going to fix the fire wall where I stuffed it from welding on the inside.
In the end the solution was easy, I just made a new section and put it straight over the top. Plugged weld a few spots around the edges and glue the middle sections with silaflex.
Re: LS1EK
Thats the trick,
You can tell your engineer that is double plated to increase the strength, should get some points there.
I'm assuming that black is epoxy primer you will rub back once the painting starts ?
Keep going mate your on the home stretch.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Yep, black is epoxy primer, I also applied copper weld through paint where I welded the plate on to the fire wall.
Re: LS1EK
Good work Simon. You have to get creative with solutions sometimes.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Finals got the inner guards painted in stone guard.Next job is to finish off the engine bay.
Re: LS1EK
Lookiing good mate :thumbsup:
Re: LS1EK
Progress is good,
I ended up painting over the stone gaurd, it still chips though.
Its hard to convince yourself to drive a car once you spend years building it, noises, oil leaks, steering feel and the dreaded stone chips !
Keeping underneath gleaming is a task on its own.
Looking forward to your reassembly.
Gregf
