Neil's FB Station Wagon
Re: Neil's FB Station Wagon
Decided to get a tailshaft made so that I can physically check alignment of gearbox and diff, then I can lock down the engine mounts and finish the gearbox mount.
Final drive have made my last two tailshafts so it was a no brainer to go back to them.
Image (1).jpeg (213.7 KiB) Viewed 3167 times
They provide an adapter at the diff end that eliminates the rubber donut that VE diffs use and gives you a Uni joint at both the diff and gearbox ends.
Image (2).jpeg (258.78 KiB) Viewed 3167 times
Not cheap but really great quality.
Very noice mate.
Got into the workshop this weekend and after having the engine and gearbox in and out 3 times I finally got it to where I think it is closest that I can get it to the right angle and the tailshaft again as close as I can get it.
Image (3).jpeg (251.22 KiB) Viewed 3111 times
Welded the mounts in fully.
Image (5).jpeg (264.51 KiB) Viewed 3111 times
Relieved the chassis to be able to get the oil filter in and out.
Image (4).jpeg (214.39 KiB) Viewed 3111 times
Think the tailshaft is close or as good as I can get it :crazy: :crazy:
Image (6).jpeg (123.64 KiB) Viewed 3111 times
Great progress Neil
Not as much as I really want Clay but I don't have the luxury of walking out the back door and going into my workshop anymore so I'm trying to get as much done as I can.
I'm still waiting on spindles from Stub Tech, once I have the front on wheels the Rev is going to Keith to get the last big bit done, the replacement of the upper firewall and dash.
Engine needs to be overhauled/refreshed soon and then all the rest mate. :roll: :roll: :roll:
melly
Post by melly »
:thumbsup: Just caught up on the progress of the reverend Neil- great job, that’s some good looking gear you’ve got there. Impressive work
Cheers melly
Have started work on the repairs on the guards, usual place
Image (1).jpeg (196.76 KiB) Viewed 2746 times
Image (2).jpeg (154.43 KiB) Viewed 2746 times
trying to make headway
Brings back nightmares, trying to get that crease along the top right. Very slightly convex.
Ha Ha Nightmares,
Sometimes I sit back and ask myself why do we punish ourselves with these dinosours, but then reality hits, what else is there to do ???
Good Job Neil, Fun Fun Fun.
FireKraka wrote: Tue May 19, 2026 3:03 pm Have started work on the repairs on the guards, usual place
I may have a patch panel for that Neil if you are interested. I had one for each guard, but used one on Wilma. Will have a look if you are keen.
Not much left and both bits LHS.
Thanks for the offer Brett but I have a pair of old Taylors panels that have the sides as well as the top sections.
And yes it is hard to get the top line lined up properly that's why I didn't show the photo of the passenger side I tacked in, got it slightly out so am going to have to go back and cut again, oops :lol:
Purchased one of the Chinese GPS speedo's that Brett purchased from eBay, looks pretty good but a little worried that it does not sit on Zero unless it needs power to zero, will see when it goes in.
Image (9).jpeg (191.29 KiB) Viewed 2178 times
Finally received drop spindles and came up against the same issue I had with Frank.
Adapters fitted to stub axles.
Image (12).jpeg (215.75 KiB) Viewed 2178 times
Ground clearance on the VT twin piston callipers
Image (13).jpeg (164.94 KiB) Viewed 2178 times
Crossmember and control arms went to Keith, he has painted in two pack
Image (10).jpeg (221.17 KiB) Viewed 2178 times
Image (11).jpeg (214.98 KiB) Viewed 2178 times
Good progress Neil, the adapters are a bit of a worry if they are supposed to suit that calliper.
