Westward Ho!
Re: Westward Ho!
Safe flight home mate , was great to catch up :thumbsup:
Re: Westward Ho!
WA crew are tops ImageImageImage
Good to get home to a couple of my favorit things though......Image
Re: Westward Ho!
Clay good to hear your home.
You put the mockers on me ! I'm crook as a dog and still have a few days to go !!
Thanks for all the updates in your blog. I will do one once i get home.
Re: Westward Ho!
Bugger. Look forward to a lung full of sludge…
Re: Westward Ho!
I collected the ute from CEVA this afternoon, after bus, train, bus and a half hour walk through the seedy streets of Wingfield. All in order. 3205 miles, or 5157km travelled, door to door. 565 litres of petrol, mainly 98, for an average economy of 25.8mpg, or 11.0 litres/100km.
briby
Re: Westward Ho!
Post by briby »
Well done Clay, nicely tuned i'd say, or the cruise control worked well :lol:, i got 23.8.
FB Restomod V8 Sedan
Re: Westward Ho!
Re: Westward Ho!
This has become an annual post Nationals ritual, drying out.ImageIn the rear was only a thimble of clean water lying in a corner of the tank surround lip, which only got in from a puddle in the cover, when I took it off wet after hosing down post CEVA pickup.ImageThe front has some slightly damp dust,debris and insulation, the removable bits on the floor flats.ImagePretty good really.
The other reason for taking everything out is to try and eliminate the two metallic squeaks that plagued me on the after tour. I certainly won't be taking it out for a test the next couple of days as it's raining Ike SW WA currently. Miserable.
Re: Westward Ho!
Where are the cabin leaks Clay? I'm wondering if a bloke should be having a look around his ute and learn from your experiences😀
Re: Westward Ho!
It's the front screen, Brett. It's not too bad, and I could possibly remedy it with some attention. Such a fraught design really.
Re: Westward Ho!
Hmmmm…. My front screen on the Ute leaks too on the passenger side. Bit of a pain but it is not often out in wet weather.
Re: Westward Ho!
You need to bring it to Temora next year, Stephen.
Re: Westward Ho!
Mine has been opened up and left to dry for the last 2 weeks, we flew back in on Thursday so I will check it out this weekend , maybe pull the head off and check the damage
Wrongway Roger
Re: Westward Ho!
Post by Wrongway Roger »
Just so that you know that I care about my crusty wagon, I lifted the radiator cap the other day and the tank was half filled.
Good to go again.
Re: Westward Ho!
