Harv's FED thread
BS
Re: Harv's FED thread
Post by BS »
All good progress Harv!
I would have thought some old drum brakes to keep it period,
Going fast is so much fun but i suppose if you cant stop thats an issue.
It's on the border line where it almost needs a chute. It will get one, but may not need to use it. The discs will give me piece of mind for a while until I get used to how this thing works... agree that drums would have suited the era better.
Life behind bars.
A lot more cage than the simple rollover hoops of the 60’s. My noggin is probably not worth the steel price (too much armour, not enough brains) but needs to be IHRA compliant to run.
Full on Harv
It is some beautiful bar work.
Warning stuff to sit on top of the rearmost rocker cover bolt (no gauge panel on a FED… no time to look down). Water temp for when I cook it in the staging lanes, and a big red flashing “get your boot out of it ya idiot” light.
BS
Post by BS »
Good stuff
I had a Hella trailer brake light with a big dollar sign on it as an oil pressure warning light in my speedway car .....
Blacky wrote: Mon Oct 03, 2022 10:58 pm I had a Hella trailer brake light with a big dollar sign on it as an oil pressure warning light in my speedway car .....
:lol:
Dr Terry
Post by Dr Terry »
Are those nylon ties "period correct" ?
Dr erry
Dr Terry wrote: Tue Oct 04, 2022 8:51 pm Are those nylon ties "period correct" ?
I had some bailing twine, but figured that was overkill :lol:
Tried to think of a neat way to secure it without the cable ties, but failed. Difficult to bolt through, as the gauge takes up most of the real estate in the cup. Could glue it, but that didn't feel right either. Maybe some stainless panduit straps.
Hose clamp?
Stygian
Post by Stygian »
Hi Harv,
If that's a new Smith's mech temp gauge, be aware that the soldering on the sender of these new gauges can be of a very poor quality and are prone to fail. After mine died, I took it to a mech gauge guru, an ex-QANTAS instruments engineer I've known for years, who re-machined and soldered the sender after filling it with anesthetist aether. Cheers.
Ta - a good heads-up.
