Project 2.
Re: Project 2.
Thanks Clay. Thought so, but needed to be sure.
Re: Project 2.
and will need spigot bush ...............
Re: Project 2.
I noted your post about spigots Blacky🤗. Also how you used the bolt and grease to get it out.
Re: Project 2.
Sent you a pm Clay but it bounced cause your box is full or something technical.
Re: Project 2.
Brett027 wrote: Mon Feb 08, 2021 7:29 pm I noted your post about spigots Blacky🤗. Also how you used the bolt and grease to get it out.
I use wet newspaper to get them out mate, way less mess than grease ........
Re: Project 2.
Brett027 wrote:Sent you a pm Clay but it bounced cause your box is full or something technical.
Deleted a few messages Brett so try again if you like
Re: Project 2.
Didnt know about wet newspaper- how does that work?
Re: Project 2.
Just tried again Clay and it bounced again and says you are over quota. I'll try tomorrow
Re: Project 2.
Deleted a whole lot more
Re: Project 2.
Brett027 wrote: Mon Feb 08, 2021 8:17 pm Didnt know about wet newspaper- how does that work?
Exactly the same as grease , also heard of people using bread - never tried that because it sounds stupid to me , you just need something that is incompressible and malleable I guess. The wet newspaper works well and i just leave it to dry and its easy to dig out and clean up
Re: Project 2.
Gathering bits together. HR front and back brakes and axle and steering stuff, collapsible column and a few other goodies. Image
Re: Project 2.
Brett,
The HR front suspension has LC-J Torana discs and calipers fitted to it. But it probably won't make any difference from a user's point of view.
Re: Project 2.
Thanks Rob, I wasn't sure, so good to know. I wish you visited more often😀
Re: Project 2.
Brett027 wrote: Mon Feb 15, 2021 2:48 pm Gathering bits together. HR front and back brakes and axle and steering stuff, collapsible column and a few other goodies. Image
Brett
Utes come in handy for storing junk, that is until you want to drive it and you have unload them first :frownn:
Re: Project 2.
Just a bit of forward planning while waiting for paint to dry...
What are people using for the reinforcement panel inside ute sills? I have some to do.
