Alternator
BILLY BLACKARROW
Alternator
Post by BILLY BLACKARROW »
A Question
for Greg ,Harv , and anyone else running a V8 ---What Size Alternator are you running and is it low or high mount Photos will help with positioning
OH Greg do you want to rent out your wheels when it comes to rego time for me as I have 15" on back & 14" on front :wink34: just to drop the front a little more :blushh: :blushh: I have HZ HQ stud pattern
BILLY BLACKARROW
Re: Alternator
Forgive the old photo (2007? really? :oops: :oops: )
EK wagon alternator.JPG (1.43 MiB) Viewed 860 times
Bosch BXU12121A 120amp unit, driven by a Bosch 11A1065 fanbelt. Low mount, just clears the sway bar. Car starts, but idle speed is not enough to excite the alternator (lazy, lumpy old Chev) and idiot light stays on. Blip the throttle, alternator gets enough revs to excite it, and the light goes off (and stays off).
Re: Alternator
Hi Billy,
https://www.ebay.com.au/itm/SMALL-CHEV- ... ctupt=true
I think my alternator is 80amp, and like harvs is a bosch. I bought an exciter kit which I posted before to kick start the charging, it comes with an electronic box as big a match box and led light. If you use a globe it needs to be a certain wattage (can't remember the size 3 watt maybe ?).
My wheels are also 14 inch HQ front and &*#@ rear stud pattern.
Thanks
Re: Alternator
A couple of photos Bill.
My adjuster / slide is on the bottom.
BILLY BLACKARROW
Re: Alternator
Mine is similar to your's Greg but adjusting bracket is seperate I had to lift my motor 3/8" to clear steering shaft I wouldn't think that it would make that much difference but I can't get it to fit properly there doesn't seam to be enough room between motor and chase rail
Harv is your's homemade
BILLY BLACKARROW
Re: Alternator
Bill,
Forgot to mention my rail has been shaved a bit for clearance.
Harv's Alternator is also attached at the block where as mine uses the bracket, Harv's is closer to the engine.
Re: Alternator
Yep, my bracket is home-made, cut out of a bit of plate.
I promise I painted it and replaced the fasteners sometime in the last 13 years :lol:
BILLY BLACKARROW
Re: Alternator
OK
I have got mine sitting like Harv"s I think from what I can see your earth is in the way Harv :lol: you have mounted in the lower hole in the block and you adjusting bracket in the top hole with home made bracket It's been tooooooo cold and wet for an OLD bloke to be working in the shed today and I have a dental appointment tomorrow so that's out to. All I have to do now is to work out my adjusting bracket setup if I can't do that I will go back to a high mount fingers XXX
BILLY BLACKARROW
Re: Alternator
BILLY BLACKARROW wrote: Sun Jul 26, 2020 4:37 pm you have mounted in the lower hole in the block and you adjusting bracket in the top hole with home made bracket
Yep - that’s how mines mounted.
BILLY BLACKARROW
Re: Alternator
Thanks and for the photo's as well :starr: :starr:
BILLY BLACKARROW
BILLY BLACKARROW
Re: Alternator
Does that No decipher the diameter of the belt ?
120 amp unit, driven by a Bosch 11A1065 fan belt.
BILLY BLACKARROW
Re: Alternator
Automotive belts are made to SAE standard SAE J636 V-Belts and Pulleys. Metric belts are labeled in three parts:
• A number denoting the closest mm width of the belt (eg an “11” belt is roughly 11mm wide). This ranges from 6 to 23.
• The letter A, denoting automotive
• A number denoting the belt length (e.g. “990” for a belt that is 990mm long).
Most automotive aftermarket belts that are readily available in Australia (Bosch, Dayco) are metric automotive. Note that Holden grey motors use two different types of pulleys – a wide belt on the earlier Holdens (FX and FJ), and a narrow belt on the later (FE through EJ) grey motors. For FX and FJ Holdens, a type 15A belt is used, whilst the later FE through EJ Holden grey motors utilize the narrower 11A belts.
BILLY BLACKARROW
Re: Alternator
Thanks Harv
You are a wealth of knowledge :esurprised: :esurprised:
BILLY BLACKARROW
