Red Rattler Revamp
Re: Red Rattler Revamp
Nice work Mr Black can't wait to see that engine in there and turning.
what suspension mods have you done? looks like its missing a few? flipped it?
Rear springs reset mate
Finished all the painting today and started putting bits back on
Got the zorst, diff and shocks in plus the pedal box and booster mounted. Had to cut some bits off an old diff out of EKMart as the diff bloke didn't refit the bump stop brackets or the mount for the brake hose
Had a go at finishing off the home made collapsible column , found out it doesn't quite go together as per the directions on the forum, got a 1/2" gap between the wheel and the indicator section, will need to machine some circlip grooves in the shaft - not sure I have the right tooling to do it at home will look tomorrow
Exciting bit now the painting is done.
You’re running original style bump stops then, not EJ type which fit under the u bolt tops?
Yep , if it aint broke ..............Errol62 wrote: Sun Jan 26, 2020 10:24 am
If you want to go really low I think you can use later Torana bump rubbers in the EJ setup, which are shorter.FB ute fixer upper, EK van on rotisserie
LC/LJ bumpstops in EJ/EH cups use them as much as i can, cutting originals down works find of but not as good as the LC/LJ stopsErrol62 wrote: Sun Jan 26, 2020 12:51 pmIf you want to go really low I think you can use later Torana bump rubbers in the EJ setup, which are shorter.
Mum blacky is picking on EKs againBlacky wrote:Step 2 mark the cut and cut out the dodgy bit
Got the steering column sorted out today , had to machine a couple of circlip grooves plus make up mounting brackets under the dash , fiddly time consuming job
Before -
Before -
After
You can see the grooves here, ended up moving them 12mm
Had to change the angle on the mount at the firewall end , welded a bolt on the pedal box that picks this bracket up
Finished product , cost around $120 In bits
Nice work b
