LS1EK
Re: LS1EK
Hey Taz
In my small amount of knowledge on the subject I have always believed that most off the shelf headers or extractors, which ever you wnat to call them, are not tuned which from what I'm gathering is what you are taking about.
I have thought that tuned headers have all pipes the same length this assists the engine with scavenging of other cylinders and gas flow; this is really needed on high performance engines where gas flow etc. are paramount.
Happy for others to correct this and educate my basic knowledge.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
FireKraka wrote:Hey Taz
Yes that is what i am saying. I think primary lengths around 830mm is what I should aim for but i also read that as long as the primaries are within 100mm of each other all is fine.
Sent from my LG-K500 using Tapatalk
Re: LS1EK
G'day Taz,
Can you still get good access to #2 and #8 plugs? Looks tight, but hard to tell from the photos.
I think I might need to get a mini-me to change the #8 plug on my wagon :oops: ... need pixie-fingers.
gledge
LS1EK
Post by gledge »
Hi guys the length and diameter of the pipe really depends on a lot of different factors including compression,cam lift and duration,rev range stroke etc. there are a few good programs to work it out.. the one I used for mine was pipe max but you will need all the info about every aspect of your engine to work it out.. and I don’t think that there is a free version for it so you would need to find an engine builder that has it. And at the end of the day I think you will have big dramas trying to get it all correct in such a tight engine bay and the gain in power probably isn’t worth the hassle unless you are chasing every horse or quarter mile timeImage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
After just spending an hour playing around with the pipe lengths, positions etc I have come to the same conclusion. Which is that there is not enough room, i will try to get the lengths as equal as possible but fitting it all in will be the deciding factor. At the moment it looks like this with room to remove the spark plugs, thanks Harv ImageImageImage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Started fitting the radiator, i think everything should fit :roll:
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
So a few hours spent today finishing off mounting the radiator. Bit more welding to do etc. but will do that when its on the rotisserie.
Re: LS1EK
Great job you’re doing Taz. Don’t we love a spit roast. It’s the best way to make sure the beast gets cooked to perfection.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Errol62 wrote: Sun Aug 19, 2018 6:50 pm Great job you’re doing Taz. Don’t we love a spit roast. It’s the best way to make sure the beast gets cooked to perfection.
I wondered what you were on about😄😄 spit roast, cooked to perfection 😂😂😂
thebrotherj
Re: LS1EK
Post by thebrotherj »
TAZ wrote:First crack at mocking up the drivers side extractors. Looks as if extractors will be one piece as i can remove the steering shaft when installing or removing them. Still a long way to go yet as i have not positioned the collector etc. Will also need some hi-temp glue ImageImageImageImage
Good to see the spirit of ol’ Brian Plankkman is alive and well in your build Taz!!
Top stuff, keep us posted.
Joe
Re: LS1EK
He was ahead of his time , Plankkman was :ebiggrin: :ebiggrin:
Will
Re: LS1EK
Post by Will »
Looking good! Ive just got my radiator fitted and extractors and whole exhaust system doneImageImageImage
Re: LS1EK
Looks very nice Will I think you had better start your own thread if you haven't already and show us more photos mate.
Looks like you have a 4 link rear and independent front end would love to see more.
Sorry to abduct your thread a little there Taz.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Will wrote:Looking good! Ive just got my radiator fitted and extractors and whole exhaust system doneImageImageImage
What extractors are you using? Can you send me some photos of where the extractors come past the engine from underneath?
Will
Re: LS1EK
Post by Will »
I havent got any pics of the underside sorry. Its the castlemaine rod shop front end with the ls mounting kit and exhaust kit. The starter motor gets put on the passenger side to make more room for the steering.
