Leroy’s back on all fours.
Little hard to tell from those crappy photos, but the ride height seems pretty good after a good bounce, will torque everything to spec when I get home tonight. Could maybe go half an inch lower? Bag of cement in the tray? LHF tyre is flat and the other three are all different sizes
so I won’t truly know how it sits till I get wheels & new tyres sorted.
Had a tricky time aligning the exhaust - Bill must have backed it into a tall gutter real hard at some point, there’s even a dent in the floor where the bend over the diff has impacted. Might be a little close to the fuel tank when that goes in so may need to re-hang it all. New rubber hangers also threw it out of whack from before.
Brakes bled up ok. No leaks from the new hose and metal lines, or the old wheel cylinders... they must’ve been replaced just before the car was parked, fingers crossed they hang in there. Pedal is solid. Diff pinion seal is holding oil (rejoice!) with level set a little below the line with the arse up in the air. Damned hand brake cable is all set up despite a bunch of cursing while trying to get those bastard retainer bolts in near the spring eyes. Bah.
I’m not a huge fan of lowering blocks, I haven’t used a set in over 20 years, but this seems to sit ok, pinion angle is better than I remember, last time I used wedges if I recall. Guess I’ll lop some thread off the bottom of those U-bolts once I’m satisfied it’s all kosher. I also prefer two locknuts to Nyloc nuts but I’m sure it’ll be fine, right?...
Shackles look to be sitting right too, suspension feels good with all new bushes and shocks.
Fuel tank will go in next - do folks use caulking compound to seal the fuel tank flange to the floor?
Cheers, Joe
