Standard grey motor fuel consumption
Super versus unleaded.
Super fuels in the good old days contained lead and a good octane rating.
Older cars would run with allmost any compression ratio as high as 11 to 1. and not suffer from pinging.
Todays fuels have no lead and burn at much higher temperatures causing very fast wear on valve seats that are not hardened. The lead would cushion the valve against the seat and would help burn at lower temperatures. The increased combustion temperature with unleaded causes pre ignition or detonation of the fuel before the engine reaches it optimum firing point (hence pinging).
New cars have knock sensors and adjust the timing to suit the fuel explosion in the combustion chamber.
The older cars with lower compression can use unleaded but require an addative to replace the lead to avoid valve recession.
Octane boost also helps and if you can get the mixture right you will save fuel because it will burn more efficiently.
Of course driving style loading and even tyres will become part of the equation.
fuel
Just about off to work - you've escaped another big one.......
Thanks Greg for you information.
I have fitted unleaded seats to my head - or the head specialist did (and to the engine head - not mine!).
He tells me it will live for a thousand years............ and if I plan to keep it long time......... love you long time Hangley........... to continue to use the additive - I use Flashlube - but exactly to the recommended dose.
He tells me a lot of trouble comes back when people become "kind" to their engine. Do not over-dose - it builds up and leaves deposits in the head, inlet manifold and chamber parts. Better to slightly under dose than over.
He tells me that it is not possible to get unleaded valves - only the seat inserts or replacements. For that reason alone he suggests using the additive.
I use Optimax, Ultimate, or Vortex but on figures I am averaging, it would appear at present Ultimate is giving very, very marginal higher figures ........ I realise this depends greatly on all variables. and as members of my Victorian club would point out very quickly, my bus doesn't get out much -perhaps resulting in evaporation.................
On the question of VSR - the explanation given to me was that with all current unleaded fuels, the valve seat actually welds (micro - micro scopically) with the valve itself, when they part - the seat is of softer materieal than the valve and this eventually causes the seat to deteriorate under the continual pounding and parting from the valve under its spring - hence the seat recedes.
If you run solid lifters or in the case of a grey motor - be careful - this will reduce your rocker clearances - it is probably not enough to do damage if you keep them regularly adjusted, but be aware of it. I don't believe there is issue if you are using a VSR prevention additive.
The advantage of the additive is to provide a "powder coating or insulation" on combustion and this coats the valve and seat in its exhaust through the port..............but don't overdose in the belief it will make them last any longer.
just my thoughts for today............
oldnek what's yor explanation for the van makes no difference what i run that on either
a mate who races big motor bikes and is a mechanic who did alot of fuel research reckons unless yor constantly sitting on 3,000 rpm or more there is no need for hardened seats or additives but it doesn't hert
additives (not octane booster) also drop the octane rating of the fuel
revs
Hi Ratbox,
thanks for your information.
I can make some sense of this - to my limited knowledge it would appear that we are referring to the heat of the exhaust?
I am of the opinion that when I tow, and have to use maximum power over an extended period - I would want to have the comfort of knowing that the valve/seat are receiving some insulative support to that great heat - which must exists even below 3K rpm.......... I would like to hear more on this, it has re-opened my mind on the subject.........
heat
driving big bangers ,i have found that cause they have a pyrometer that when the revs drop under load exaust temps go up and if you go back a gear to increase revs or just increase revs in the same gear that the exaust temp drops im thinking due to increased air flow and water pump speed that air flow helps to cool by takeing heat away more quickly its a hard one to guess a temp reading test would be available on a dyno maybe someone mite know
Thanks craig.
Forgot to mention, standard stromberg with aftermarket air filter. Nothing flash. 8km/L seems average for highway by the looks.
On a side note, the car needed every seal replaced after the drive. It seems that the previous owner rebuilt it and thought that roofing selastic would be an ideal replacement for gasket goop.
No need for aditives with the new seats
I run both of mine on Premium but thats a personal preferance as some of the covinence stores that sell fuel sell crap steer clear of the ethonol shite (remember when you got service at a service station cant even buy a plug lead at most of them these days but you can buy condoms and breakie cerial dont eat them together kids)
Just of topic for a sec got a new work car this week a Diesel &*#@ Transit open the fuel door and it says unleaded only
F wits
Better dead than red
EK, the VN of the 60s
got told a little something, don't know how true it is and it's not really relavent to FB/EK's, a mate has a mechanical work shop they've had a spate of catalytic convertor probs and were told apparently the E10 stuff burns alot hotter and is causing the porcelain in the convertors to melt
i think i've said it before, but i run all types of various fuels in my various cars everything from mild red 6 to carbied and injected V8 and an ecotech V6 and it has made absolutly no difference to consumption or performance
