Caps on Roh rim?
ddrummond
Caps on Roh rim?
Post by ddrummond »
Hi guys,
I recently bought a set of black roh rims 13 x 4.5, I've been trying to fit the FB hub caps on there but I'm struggling and i don't want to damage the caps, do you know if they even fit? If not do you know where i can get some baby moon caps or something nice? what are my options?
Black Roh 13 x 4.5
Black Roh 13 x 4.5
Re: Caps on Roh rim?
I vaguely remember an old post discussing these rims. Try searching as I think it was quite a few years ago. Fairly sure they're not such a great fit.
I have ROH chromies 13x6 & 7" off my sedan and ran stock caps on them for years. They were s tight fit. Have you got a rough cap you can have a go with? Two lugs home then palm hit a la stiff arm or rubber mallet.
ddrummond
Post by ddrummond »
Errol62 wrote:I have ROH chromies 13x6 & 7" off my sedan and ran stock caps on them for years. They were s tight fit. Have you got a rough cap you can have a go with? Two lugs home then palm hit a la stiff arm or rubber mallet.
I've got a fairly rough one I'll give a go with the mallet.
fb cruisin
Post by fb cruisin »
I ran them foe a while and got sick of losing caps. They don't have the little ridge that holds them on.
Cheers Rob
______________
living the dream.
ddrummond
Post by ddrummond »
fb cruisin wrote:I ran them foe a while and got sick of losing caps. They don't have the little ridge that holds them on.
Cheers Rob
Mallet worked but just like you said they kept on popping off, is it worth using a grinder to create a ridge?
BILLY BLACKARROW
Post by BILLY BLACKARROW »
Or a few tack welds around the rim where it sits then you can grind them to suit just how I would look at it
BILLY :arrow:
BILLY BLACKARROW
Mine have a bit of a ridge. ImageImagecaps stay on no problem.
Craig Allardyce
Post by Craig Allardyce »
Tack welding or grinding wheel rims?????? Be careful of causing cracks!
FJWALLY
Post by FJWALLY »
I had the same issue - they just don't have anywhere near enough ridge to hold the caps on - the only way to get them to lock on is to grind a deeper ridge with a dremel or grinder - it's rough and I don't like it either so I've kept the original rims and might have them blasted and re-powder coated.
You should be able to get wider rims with your original centres welded in at the offsets you want. Rims should be separated from centres to be chromed in any case. Chromed rims with painted centres and factory caps looks nice imho.
