Deep Dish, Help Please?
EssCee
Post by EssCee »
Hi Guys,
I have seen numerous photos of EK's with what looks like Deep Dish steelies on them.
I have HK Kingswood 14x6's on my Wagon at the moment and i want them OFF !!!
Can anyone point me in the right direction on how i get the set up? Any help would be appreciated.
Thanks
(I have a HR Disc Brake front end)
Re: Deep Dish, Help Please?
withou knowing what you want as far as wheels go i can't help much BUT i could be interested in those 14x6" wheels if they are 6" and not just standard :thumbsup:
mph
Post by mph »
I had mine (hg 14's) done by a guy in WA, the offset was to wild so i had them pulled in slightly , the rim is also flipped so you cant run a chrome trim ring im told yet to test.
At first he tried to recomend another guy but because im a mate of a mate of a mate etc he said he would do them.
If you would be interested in sending them across Aus or something ill find his details
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
EssCee wrote:Hi Guys,
Thanks
To get any kind of dish on the rear you should start with a LJ Torana rear end.
I have reversed 7"rims on my ute with a stock front end and Torana diff and have no clearance issues but the increased scrub radius makes it heavy to steer- but they are 13" , Trevs (now Oli's) wagon looked the goods and I have thought about converting to 14" to get the same look.
mph
Post by mph »
Thanks
If you can find one, i was looking for one to go down this path but with no luck had the rims pulled in 30mm,Vehicle still to lowered some more.
:laughinggg:
phase 3 131.jpg (61.57 KiB) Viewed 1575 times
phase 3 096.jpg (66.64 KiB) Viewed 1575 times
phase 3 095.jpg (73.25 KiB) Viewed 1575 times
FB-Special
Big block 161 :lol:
Holley sniper EFI.
FBeing
Post by FBeing »
Go and see Wal from Neale Wheels if you want get some made.
He did my ROH 15 x 7 steelies
Obviously it'd be cheaper to get some already out there
The W.A. equivalent of Neales Wheels is Stan at Wheelmodz - he is THE man to see in W.A. for wheel modification, fabrication , etc.
See here - https://www.facebook.com/media/set/?set ... 089&type=3
rosco
Post by rosco »
I'm in the middle of this battle at present - but with Dragway alloys.
I have HR front end and EH rear.
If you go 14x7's - and want all wheels identical, you'll have issues with the front upper ball joint at full deflection (relieved).
I have fitted 2 X-U1 spacers each side - and all front issues are resolved.
The rears will scrub on the 2/3 mark back along the wheel arch if your outer rim is more than 3 3/8" from the wheel mount face on a 54 1/2" rear housing.
Fitting anything on top of the left hand side spring in the form of an over-rider to the rear of the axle, which protrudes inwards will foul the spare wheel well....
If you go the Torana rear housing - I'm a bit concerned the inner tyres will foul the body frame in the wheel arch on mine - and I expect the same with others.
I run "high" - I appreciate many/most now run very low to the ground.
We scrubbed a couple of times yesterday on it's maiden run - bottomed out pretty heavy on a ditch at speed on the blacktop.
Even thought he over-riders are wound up pretty tight - and the adjustable Koni shockers were wound out another turn - there was still a good 1 1/2 inches of upwards travel when be bottomed - that is evident by the scrape on the wheel-well...
Make absolutely certain you get your offset right... 14 x 6" wheels shouldn't be an issue - but you'll need to get clearance under the outer wheel arches if you intend to run it lowered.
14 x 6's wont be an issue up front - it's the upper ball joint housing which scrubs with 7's... tie rod end is fine.
