I enjoyed it so much last time.
I didn't grease it the first time and it was very tight to move, although it had got a lot better.
All greased and re-installed and it's back to being tight again.
I expect it to loosen up again with a bit of use.
SunnyTim wasn't 100% sure if you could get the gear shaft out without removing the entire steering column.
The answer is you can.
Easy to remove
Would have been much easier with a second person inside the car to assist with the pressure on the spring.
So the next job is to get the outer door rubbers on the car.
But you need the Scuff plates in.
To put the scuff plates in, you need the carpet in.
In order to get the carpet in, you need to remove the seats.
Once I had the seats out, might as well pull out the mechanisms, redo all the padding, treat the surface rust, paint the frame and get it all lubricated and cleaned up.
