COOLERIDE VISOR
EK DAZ
COOLERIDE VISOR
Post by EK DAZ »
Could someone with a ruler, please pop out to the car and measure from the top of the windscreen (top of roof) to the first row of holes on the sunscreen bracket. Thanks, Regards to all. Daz.
EK DAZ
MeFB
Re: COOLERIDE VISOR
Post by MeFB »
Um, I'm sure you're not standing there with a ruler in one hand and a drill in the other :shock: but maybe the critical measurement would be the corner brackets? I'd think you'd have to attach all the brackets to the visor, rest it on the car (supported by a mate), make sure the corner brackets lined up evenly on the A pillars, and then that would determine the position of the top brackets on the roof?
I'm a few thousand miles away from my car just now, and sorry I can't give you the info you asked for, but I gotta ask, why do you need that measurement :?
:arrow: :D
Alan
EK DAZ
Re: COOLERIDE VISOR
Post by EK DAZ »
Hi Allan, Its just that my visor has a twist in it and the top brackets dont touch the roof together.Even if the side brackets are in the correct position, I would like a dimension to the first holes to make sure these will end up in the right place.Cheers Daz.
EK DAZ
MeFB
Re: COOLERIDE VISOR
Post by MeFB »
Ahhh, now I gotchya :thumbsup:
Sorry, I'm still miles away from the car though and can't get the measurement to you.
:arrow: :D
Alan
Re: COOLERIDE VISOR
Ok Daz , went and took a couple of snaps for ya.
The sides should sit at the same height as the door frame -
The centre bracket sits about 23mm back from the edge of the turret , I stuck the end of the tape measure between the surround and the roof.
Here is the other end of the tape -
Hope that helps mate.
EK DAZ
Re: COOLERIDE VISOR
Post by EK DAZ »
Thanks Blacky, Thats exactly what I needed. Trying to sort this out while the body is still bare metal to save scratching etc. Cheers again Daz.
EK DAZ
