The Jacksons Holden EK "Cropper Creek" Honey Beige
(AUST)Mod
Re: The Jacksons Holden EK "Cropper Creek" Honey Beige
Post by (AUST)Mod »
Wow what a transformation Steve. Can you outline the steps you did to do this and the cleaning products you used?
Also I noticed on before pics the radiator hoses had the original clamps but the after pics had new ones? Any reason for not using the original clamps?
Stewart
Aussie Bob
Post by Aussie Bob »
parisian62 wrote:Wow what a transformation Steve. Can you outline the steps you did to do this and the cleaning products you used?
Stewart
Hi Stewart. Thank you!
Step 1. degrease engine with degreaser.
Step 2. Wash engine bay with soapy hot water.
Step 3. 1600 sandpaper on rust spots (plenty of time and elbow work here as you need to sand the rust only)
Step 4. Kenco "Shift It" (plenty of time and elbow work here as you need toothbrush and a lot of time) We spent two days on this step.
Step 5. Buffing compound by hand gently.
Step 6. Mothers Scratch remover with a lot of hand rubbing.
Step 8. Preserve with WD-40
I removed the wiring carefully, the top radiator and support and horn for better access to front radiator suport side panels.
NOTE ... original Sydney cars have Colour crayon of paint name on right hand side ... be very careful not to wipe of polish this off.
Thank you,
Steve
Thanks Steve. You musn't have any fingers left! Think I'd better go get some of that Kenco 'Shift It'.
Any reason for not putting the original hose clamps back?
Aussie Bob
Hi Stewart .... Wayne and my fingers are stuffed :)
When we to the Croppa on it first trip since 1971 (the Sawtell Nationals 2011) The top hose was a little soft, so we swapped it out ... clamps and all. It will put the old clips back on ... now that you mention it :)
Steve
tm 50
Post by tm 50 »
Steve , Im curious , what is the story behind the Blue sheathing/laggging on the wiring loom in the engine bay??
regards Tony
Aussie Bob
Hi TM, I haven't researched the blue on the looms on Sydney Standards for quite some time. I think I recall Sunny Tim's EK Standard Cameo having the same blue. That is also a Sydney car.
Steve
tm 50
Post by tm 50 »
SunnyTim wrote:No mine is black, but many utes/vans and standards are blue. Seems to be a 62 thing rather than a 61 thing.
Steve - Keith's Prospect Ivory has blue insulation
Tim
Tim does yours have indicators? wondering if it could be a different loom due to a lot of commercials not having indicators?????
wot179
Post by wot179 »
Is that No3 exhaust valve bent or just stuck open?
It looks to have been run stuck open for some time.
Those marks on No2 are definitely curious.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
My 1960 FB ute is Perth assembled , with indicators and it had blue harness tape .............
Inside Tim.
samprinci
Post by samprinci »
thats some great info guys... thanks for sharing that. Which confirms my conclusion about my ute too. FB which has the black tape & blinkers fitted as an accessory see blue wire (this pix is from the resto)
www.fbekholdennsw.com
samprinci
Post by samprinci »
heres a question, noticed your (see pix circled) the volt box thingee (sorry forgot the name) its blue. pretty sure my fb is black.
did they change colour ??
choppedfan
Post by choppedfan »
SunnyTim wrote:PS Steve, don't use those crappy SCA batteries they do horrible things to wiring looms :evil:
Whats the issue with these batteries???
Mick 8)
vmx-mxr
Post by vmx-mxr »
SunnyTim wrote:
Steve Jackson wrote: Well it has been over a year since we have done anything to the Cropper Creek ute. Got time to pull the head to free up the valves. Had the factory head gasket and very clean.
Here are some pics.
Steve, from memory this car was missing no 2 plug when I looked at it on the property. What's going on with the top of the piston, it almost looks like a valve has kissed it, although there are two semi circular imprints :?:
Tim / Craig
The 'marks' on #2 are a convergence of camera flash. Look on #1 - it has a slight crescent pattern on it the second piston just has more light bouncing off the cylinder bore. Both are in the 9 0'clock to 12 o'clock position ie hit from the same angle when the flash went off. Easy !!!
Saw the engine bay first hand and it sure is clean as ! Don't know if my FB ute bay is going to come up that clean :shock:
Dave Mac :D
