Steering column
Steering column
I'm putting a turbo 350 or 400 in the ek & want column shift & to use the original steering wheel. Suggestions?
Re: Steering column
could be difficult as you need the column to be collasible .Can be done
regards fatboy
regards fatboy
Re: Steering column
hey FB how did you go with the new frontend .......Fingers
Re: Steering column
I grafted the top half of an EK column to the bottom half of a VK column , I was you I would look at using EK auto top half and HQ-Z column auto lower ??? The column change can be altered to accept a cable at the firewall so you dont need to bugger about with linkages to the left hand side of the box
Piece a piss .
Piece a piss .
Re: Steering column
Cheers blacky!.. Grey on this whole area.
Can it be done in a way so that all I see from the fire wall is the steering shaft??? Or, does anyone have a pic of a Hq column
minifb
- Contact:
Re: Steering column
Blacky make me one....... PLEASEBlacky wrote:I grafted the top half of an EK column to the bottom half of a VK column , I was you I would look at using EK auto top half and HQ-Z column auto lower ??? The column change can be altered to accept a cable at the firewall so you dont need to bugger about with linkages to the left hand side of the box![]()
Piece a piss .
FB/EKForum member 123
Woofto Car Club Member No4
Woofto Car Club Member No4IF ITS NOT CHOPPED IT MAY ASWELL BE RESTORED
Re: Steering column
No good yet man, I haven't done anything more than seach ebay.. The only one I found went for $250.. Didn't really wanna spend that much just to cut it in half.
