:shock:
- Aussie Bob
smooth
ROFLratbox wrote:you've all been fooled, the trim was done by a guy called albert johnson from albert's auto trim he had a trim shop next to a big car yard on parramatta rd back in the '60's he did a few and they modified the tag to match so in later years it would have everybody puzzled![]()
Regards, Smooth
- Aussie Bob
61FBspecial
Well.......I only have one decent picture of the seat trim. It is on film and I don't have a scanner at the moment.
However, it looked the same as your grey trim Jacko - as in same pattern in red on the inner panel and plain red on the outer. The door trims were as you would find in any other FB Special.
I have found the build plate in the garage and compared the codes with my current FB, they are different, which surprised me because I assumed the 'wacky trim' would have been an aftermarket job.
The FB I have now is Seagull Grey with Cathay Grey flash with the normal looking White with stars/plain red/speckly red seats. The trim code being 667 - 883.
The FB I scrapped was Morning Grey with Grecian White flash with 'wacky red trim' number 611 - 941. Although as I mentioned, the door trims are the same as the car I have now.
Any interpretation of these numbers from the Guru's?
61FBspecial
And by the way, the tag I have has NOT been modified in any way.
- Aussie Bob
- Aussie Bob
- Aussie Bob
- Aussie Bob
- Aussie Bob
61FBspecial
