My Ute
Re: My Ute
Some very nice work there Dave. Looking good. 8)
Re: My Ute
Nice work Dave 8)
Davet
Re: My Ute
Post by Davet »
thanks guys..
parisian62 : i was undecided on that until recently when i was talkin to a dude at the paint shop, i ended up deciding to put stoneguard under it then overpaint it with paint like the rest of the car
Re: My Ute
Thanks for your reply Dave. :) I'm still trying to make up my mind on the underbody. :roll: :)
Stewart
Davet
Re: My Ute
Post by Davet »
been priming away for a few afternoons after work, wew surprised me how long it took to do the body! i need a bigger mixing cup!
what do you guys use inside your doors? brush in something?
samprinci
Re: My Ute
Post by samprinci »
get used to that feeling, everything takes longer than you estimate... :oops: :oops:
But lookin good Dave. nice work
Sam
www.fbekholdennsw.com
Davet
Re: My Ute
Post by Davet »
hi guys been a while since i posted a update have moved house and everything so moving the ute and all its part was rather time consuming also been to a wedding and had the inlaws and so much stuff that ive barely had any time... so heres a few pics, i managed to get my hands on a pretty nice motor and a celica 5 speed with dellow conversion needs a nice clean and paint job but the motors fully reconditioned and has rollers rockers, lumpy cam all balanced, extracters and tripple strommy downdrafts on a cain manifold.
only problem is i wanted to fit my fully recoed triple SU,s for a while until i got the strommys recoed. but omg... look at the photo.. anyone else had this issue and fixed it?
as you can see also the person who done the larger gearbox tunnel stuffed up and measured wrong for the celica box so i had to cut it out again.
muza
Re: My Ute
Post by muza »
Lookin good mate
Stock as a rock
Not so stock
EKSPCL
Re: My Ute
Post by EKSPCL »
Top stuff. Keep it up 8)
My 6yr old daughter said
samprinci
Re: My Ute
Post by samprinci »
WOW!!!!!!! :D :D :D thats ganna go like a rocket! yep keep those pix come.
:thumbsup:
Davet
Re: My Ute
Post by Davet »
alright i need a few opinions and a reason for your opionin would help me greatly..
should i run, the 1 3/4 triple SU carbys that are fully reconditioned from the XU1
cut the firewall and move it back a inch behind the carbs which would also make room for my extractors and save me modifying those.
or
should i get the triple stromys reco'd and run those then modify the extractors or even make custom larger extractors if that benefits?
im really a tthe point i need to decide if i am going to cut the firewall or not and i am having trouble deciding.
also if i do cut the firewal and move it would it make an impact on room for installing aircon?
shmeagain
Re: My Ute
Post by shmeagain »
ITS SHMEAGAIN Sweet go the utes 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
basic.green
Re: My Ute
Post by basic.green »
i would go the su :thumbsup:
building the dream Rick
Re: My Ute
Davet wrote:also if i do cut the firewal and move it would it make an impact on room for installing aircon?
Yep, but it depends how far you notch it in. It will require alot of pre planning and measuring before you start cutting. How big is the AC unit going inside?
Davet
Re: My Ute
Post by Davet »
=0 no idea i havent looked for a aircon unit yet.. or a radiator...
i got my car in a million parts so i am just trying to get something done on it a bit at a time. i think i woulda been better of getting a complete one for my first renovator =\
