I rang Wade and they sent me the specs. It's 40/70 advertised duration, 237.5 @ 50 thou profile with 430 thou lift at the valve. This is a big cam and probably not streetable, but Eric told me that he drove the Crowfoot Special with this cam and he said it went beautifully.
Fortunately, Eric has been able to get some lumpy top 3.125 inch pistons from another racing mate of his. These can be machined from 12:1 down to the desired compression ratio. Could this cam run in a hot street grey with 10:1 compression? Or would it be a pig to drive? I know it would be good bye vacuum brakes.
Thommo, the cam in your FB had similar specs to this by memory?
By the way, here is a pic of the Crowfoot Special.
