Evening all,
I am searching for any info you guys may have in regards to carburettor choice, jet sizes and linkage set-ups to suit a twin carb manifold on the 138 Grey.
I have a collection of carbs to choose from:
4 x BXUV-2
2 x BXV-2
1 x BXOV-1
We were thinking the BXUV-2 we would be the logical choice, as we have four to make two good ones, but if its a bad move please let us know!
Any information would be greatly appreciated.
Matt
Grey Twin Carb Set-up
sponge_designs
Re: Grey Twin Carb Set-up
Hey Matt,
You should use two standard grey motor carbs - the Stromberg BVOX 1 which has the 1 & 1/32 venturi. Red motor Strombergs are too big - bad move to use these.
Is it a stock grey motor? If so, you should use #48 main jets. If it's a warm or hot grey then the #51s might be OK. I had a professional carb outfit do my triples recently and they said they have done plenty of twin grey set ups using the stock #51 jets.
Some guys have venturi sleeves fitted to twins. I had these installed in my triples as they are necessary. Probably not necessary for twins on a warm grey.
Linkages are available through redline - hardiman.
Andrew
Andrew
i have 2 standard grey motor carbs on mine, i thought it would run rich but it doesnt, it uses a bit of fuel round town but 8L to 100ks on the highway
