FOR ALL THOSE TUNING IN I REALLY WOULD LIKE A PARCEL SHELF IF ONE BECOMES AVAILABLE
but for now heres some updated pics for yall .
Ive set the engine in place ,mounts unfinished as yet .
Gearbox crossmember and mount fabricated.
Flattened out the floor hump to allow the seats to mount in low due to the chop.
With all this bashing on the floor the sledge hammer and bolster sure got a work out , I kept the roller door down to contain the noise .
Next day the council turns up with a complaint that I am running an illeagle business , People are yelling over the fence and you cant hear them due to the noise he said
A couple of phone calls later and its all sorted and I am totally within my rights
But I dont have any courtesy for that neighbour now poor buggers.
Started sorting the seating position and angle that will suit both me and wifey. Worked out my accelerator pedal assembly and position , I moved it across to the right some more so I can comfortably rest my foot when driving.
I calculated that I am most comfortable with my feet rested 400mm apart so Ill have the clutch pedal as close to that as I can .
The pedal assembly Im still unsure of because the box has a hydraulic setup which Id prefer not to have due to the simplicity of a cable but I havent driven anything with a cable clutch...
In this pic you might notice the subtle headlight spread .
And have also decided to use a Chev dash which Ill be fitting my guages to ,Picking it up next week and Im keen to get it in there , It will get the steering across 50mm to centre it to the driving position better and give better veiw - stay tuned
