what spares to take
minifb
Post by minifb »
rustysdungers wrote:mine is going on the truck because its an FB might drive one of the EKS though :lol: :lol: :lol:
what can one say to such a comment??? :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
FB/EKForum member 123
Dean&Jana
Re: what spares to take
Post by Dean&Jana »
on top of all that, I always carry a starter motor, as I have Hydro's
as well as, all the tools and kit needed to change a timing gear on the side of the road,
or do as Tim says, and go steel.
for some reason?? Old Al always said the fibre'ies were there for a reason...not sure what it is other than working on cars on the side of the road.
both my cars still running fibre gears :o
The FB-EK Holden Car Club of Queensland
Member Since 1993
Silver
Post by Silver »
Dean&Jana wrote:on top of all that, I always carry a starter motor, as I have Hydro's
The only reason they have them is because they are quieter than steel.
Cheers Peter
Can't get booked for bein too cool !!!!
Member of Wagga Rod and Custom Club inc
reidy
Post by reidy »
I've fitted quite a few steel gears and have had them range form quiet to a bit noisy. The noisy ones quietened down after an initial run in period.
Personally I'd rather put up with a bit of noise until they bed in than have to wait for the surprise of fibre ones failing when you least expect it. I have heard of a fibre gears failing after less than 10.000 miles in service. But hey, if changing timing gears on the side of the road is your thing, then by all means go for it :)
Bill 8)
FB-EK Holden Car Club of Victoria Inc.
Silver
Post by Silver »
On the side of the road ...... would stuff up a good trip.
Bugger that , do it before you go !!
Dean&Jana
Post by Dean&Jana »
Are the alloy one's they talk about, and the steel one's, one in the same
Tim, where do you buy yours?
Member Since 1993
Dean&Jana wrote:Are the alloy one's they talk about, and the steel one's, one in the same
No they are different :D
reidy
Post by reidy »
The alloy cam gears had issues as they fractured between the metal insert and where the alloy was cast onto it. Personally i would only fit the steel ones. The Victorian club stocks the steel gear sets at present.
Bill 8)
